Is my flywheel toast?
Old Feb 9, 2005 | 07:44 PM
an81shark's Avatar
an81shark
Default Is my flywheel toast?
i've been having starter problems and here is where the starter is getting the flywheel. is the fly wheel beyond hope,
Old Feb 9, 2005 | 07:47 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
time for a new one
Old Feb 9, 2005 | 08:06 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Originally Posted by MEGLADON
time for a new one
Yep .... that dog don't hunt. Any More
Old Feb 9, 2005 | 08:11 PM
an81shark's Avatar
an81shark
i'm not in a position to this myself. any idea's on the number of hours a shop would bill.
its my understanding that hte tranny has to be dropped. 6 hours?
Old Feb 9, 2005 | 08:13 PM
Corvus's Avatar
Corvus
My flywheel is kinda bad too, but I don't plan to change it, since I will be droping a crate by spring. By the way, I think my flywheel is in worse condition, yet I don't have much starting problems.
Old Feb 9, 2005 | 08:18 PM
an81shark's Avatar
an81shark
i put on a new starter this past summer and it worked fine until about two weeks ago. so i pulled it, figuring it got fried by the headers. i put on a new one sunday with a heat shield and it started fine till moday night (8 starts) then it was making some horrible sounds.
Should i try swapping out to anouther starter, or should i throw in the towel and get a new flywheel installed? assuming 6 hours labor, thats gonna run 5-600 with a new flywheel?
man this sucks
Old Feb 9, 2005 | 08:26 PM
45ACP's Avatar
45ACP
You do NOT need a new flywheel, you need a new ring gear!
They are easily replaced (I've done more than I can count) by someone with the right skills. You just need to find somebody locally that knows how. Call around some transmission shops. Even if none of them can do it, they'll know somebody that can.
Old Feb 9, 2005 | 08:28 PM
72LS1Vette's Avatar
72LS1Vette
If you call a repair shop and tell them what you need done they can look it up in their rate book and give you a pretty good idea of the charges. I do that type of repair myself, but it ends up being more like 6 weekends!
Rick B.
Old Feb 9, 2005 | 08:45 PM
GDaina's Avatar
GDaina
Just need a torch...heat the ring gear a little so it expands and slips off..heat the new ring gear so it expands and slips on...did this countless times....nothing to it.
Old Feb 9, 2005 | 09:04 PM
an81shark's Avatar
an81shark
ehhh, whats this ring gear you talk about?
does the tranny need removed to remove the ring gear?
i searched summitracing.com and came up with nothing
Old Feb 9, 2005 | 09:21 PM
Mod 77's Avatar
Mod 77
A Manual trans has a flywheel which has a replaceable ring gear. A auto has a flexplate. I have had really good luck using a mig welder and building up the teeth a reshaping them whith a die grinder with a cutoff wheel.I have made my daily driver GMC pickup last another 4 years doing this. It takes about 15 minutes.I could hear the spot in the starter for about the first 50 starts and after that it wore in and sounded normal. I thought this method was a big joke when I heard it but I tried it ( I had nothing to loose) and it worked.
45ACP's Avatar
45ACP
"ehhh, whats this ring gear you talk about?"
The ring gear is the component with the teeth on it. The flywheel is the part that it is wrapped around. In your photo, there is a very distinct line where the two meet.
"does the tranny need removed to remove the ring gear?"
Yes, among other things. The flywheel is thoroughly buried thus will take some work to get to it + remove it so that the ring gear can be replaced.
Old Feb 9, 2005 | 09:41 PM
Corvus's Avatar
Corvus
The belhousing/tranny needs to be removed, unless you unbolt engine, and take it out
To Is my flywheel toast?
