Difference between 14 inch and 12 inch rotor
Old Feb 9, 2005 | 08:11 PM
norvalwilhelm's Avatar
norvalwilhelm
Default Difference between 14 inch and 12 inch rotor
I installed one of the new 14 inch rotors tonight and couldn't believe the difference 2 inches makes in size.
The edges are lined up in this shot
That is a stock rotor on the right
Old Feb 9, 2005 | 08:17 PM
Corvus's Avatar
Corvus
Could someone here educate me on what bigger rotors do? I know they help braking offcourse but how? Is it because the bigger circumfrence?
Old Feb 9, 2005 | 08:29 PM
74FLCONV's Avatar
74FLCONV
I'm not an engineer, but I would guess that more braking surface = more stopping power.
D. Ocean
Miami, FLA
Old Feb 9, 2005 | 08:36 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
It's the bigger radius. The greater the distance form the center the greater is the torque when applying the same amount of force. In simpler words: it's like an extension (pipe) that you would put on a wrench...
Old Feb 9, 2005 | 08:40 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
It's like have a big, um you know, it doesn't actually help with the girls, but you have more confidance
I can say that because I was one of the first ones around here to have 13" rotors on my Vette...
Old Feb 9, 2005 | 08:42 PM
CrossedFlags77's Avatar
CrossedFlags77
If you look at the two rotors side by side the surface area would be the exact same, therefore the only advantage would be more braking torque.
Old Feb 9, 2005 | 08:46 PM
Tall Boy's Avatar
Tall Boy
Hi Corvus,
I think they stop better becauce of time+distance= stopping. The brake puts friction to more distance in the same amount of time. The same reason they put brakes on rims of bicyles.
Old Feb 9, 2005 | 08:48 PM
norvalwilhelm
I know you have the 13 inch rotors but did you post pictures of it. If you have some post them here. I would like to see how you did the hat. I would like to see anything to get ideas.
I am finishing the one caliper holder tomorrow hopefully.
The second hat was turned today and only needs fine tuning.
Old Feb 9, 2005 | 09:11 PM
oregonsharkman's Avatar
oregonsharkman
imagine trying to stop a spinning wheel by grabbing the center versus grabbing the very outside..big difference
Old Feb 9, 2005 | 09:12 PM
EDDIEJ82's Avatar
EDDIEJ82
Norval, Just courious why did you go with the angled hole pattern on the new ones instead of straight out like the old ones. Is there an advantage to the angle holes?
Old Feb 9, 2005 | 09:15 PM
Twin_Turbo's Avatar
Twin_Turbo
curved vane rotors.....
Old Feb 9, 2005 | 09:24 PM
norvalwilhelm
Twin Turbo has it. None of those holes is on the same hollow between the vanes.
Each hole has a heavy wall or vane protecting it from the next hole to prevent cracking.
I never had a single crack in my other stock rotors and they have many holes in the same hollow but at $512 for 2 rough rotors and all the warning I read about drilling holes I didn't want to take a chance of putting two holes next to each other.
I posted close up pictures of the rotors in another post a while ago and showed how each hole is seperated by a vane.
Old Feb 9, 2005 | 09:27 PM
norvalwilhelm
Marck I emailed you today offering the computer program for drilling any hole pattern. It is about 1 1/2 meg and really easy to use.
Need an digital readout to use it but if you ever have access to one it sure makes drilling ANY bolt pattern easy. Square round or any other shape.
Old Feb 9, 2005 | 09:29 PM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
Norval,
Thanks for your help with my C5 rotor conversion. I only need to find an 8in 6061 bar to make the hats! Sure would like to see pix of your caliper brackets. Are they aluminum or steel?
Larry
Old Feb 9, 2005 | 09:47 PM
ZD75blue's Avatar
ZD75blue
Norval... Could you email the program to me as well? Sounds pretty cool...
My email adress is rocknrod at gmail.com @ replaced with at for spam prevention...
Old Feb 9, 2005 | 09:50 PM
Corvus's Avatar
Corvus
I'v just been schooled.
Old Feb 15, 2005 | 10:15 PM
Retro78's Avatar
Retro78
Craftsmanship and attention to detail! Norval, I need to come over for another visit soon to see the finished project in person. The pics are great but do not compare to seeing it up close.
To Difference between 14 inch and 12 inch rotor
Old Feb 16, 2005 | 04:43 AM
Turbo-Jet's Avatar
Turbo-Jet
longer lever = more leverage = easier to modulate and more torque (using same about of force)
also,
larger disc = more mass (usually) = more thermal capacitance = steadier temps = less fade
Old Feb 16, 2005 | 08:43 AM
427V8's Avatar
427V8
I did post a pic of it, last summer sometime. Yes it's a pretty bad pic.
I have a better camera now but the car is still in storage....
I used the Vette Brakes aluminum hubs and some custom Coleman rotors. The hubs are solid aluminum and quite heavy, I'm sure I could remove a lot of material.
Here's the hub/rotor assy They only sell stock sized rotors, but will sell the hubs bare.
The nice thing is that the hubs are the same diameter as the center of the 17" TT2's and gives a nice clean look.
The rotor being undrilled looks huge, drilling seems to make them look smaller...
BTW, since I know people will ask. The black stuff above the cutouts is from welding not from the exhaust.
Old Feb 16, 2005 | 08:58 AM
norvalwilhelm
They do look huge. Mine are a different style since my hat is hollow and I use the existing hub, Mine are more like stock in that they just slide over the studs.
My hat also shows alot because it is 10 inches.
