[video] First drive in the Vette...
Old Feb 9, 2005 | 10:29 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Originally Posted by isosceles
the audio in that camera must be really hosed. you can barely hear yourself scream in terror in that car! I should've had to turn down the speakers.
That high stall toque converter seems very streetable.. How do you like it so far?
Well - there's a noticable slip, but it ain't too bad.. Tranny temperature went up to 150 degrees... Coolant was higher than that because I was only running one of the little fans.. Still have to install a new permacool fan.. I got a 14 inch instead of the 16 inch fan because there isn't ehough space for the 16" fan because of the tranny cooler...
Might replace the dual Flex-a-Lite fans with the 16 " Pernacool fan.. Haven't decided yet..
Old Feb 9, 2005 | 10:43 PM
isosceles's Avatar
isosceles
Originally Posted by GrandSportC3
Tranny temperature went up to 150 degrees... ...
...reported mine to Bowtie at 159 after the tests they have you run. Of course those test have a bunch of full throttle accelerations in all gears ,then one throug 1-3. They said no problem. I'm still going to install a separate cooler though and I'm not putting it anywhere near my radiator. That's the whole purpose of the separate cooler, at least IMHO.
I saw a Permacool one with its own fan that can be mounted anywhere.
Old Feb 9, 2005 | 10:44 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Sounds pretty mean congrats
Old Feb 9, 2005 | 10:48 PM
GrandSportC3
...reported mine to Bowtie at 159 after the tests they have you run. They said no problem. I'm still going to install a separate cooler though and I'm not putting it anywhere near my radiator. That's the whole purpose of the separate cooler, at least IMHO.
I have a pretty heavy duty cooler.. It's actually for trucks towing motor homes...
Old Feb 9, 2005 | 10:49 PM
GrandSportC3
I was pleasantly surprised how streetable the 4500 converter is... It slips, but not as bad as I expected...
Old Feb 9, 2005 | 10:50 PM
shoptek's Avatar
shoptek
What torque converter are you using??
NEVERMIND>>>>
Old Feb 9, 2005 | 10:53 PM
GrandSportC3
NEVERMIND>>>>
The converter was custom built for my application and was almost $1k . It's a none-lockup race converter...
Old Feb 9, 2005 | 11:11 PM
Stewart's74's Avatar
Stewart's74
OLivier.....Awesome.......simply Awesome!!!!!
Old Feb 10, 2005 | 06:28 AM
GrandSportC3
I might try to make a better video with better sound today when I get home from work!
Old Feb 10, 2005 | 06:47 AM
USA-VET's Avatar
USA-VET
Old Feb 10, 2005 | 07:24 AM
norvalwilhelm's Avatar
norvalwilhelm
Sounds really good Oliver. I would have thought with open side pipes that is would have been louder.
Old Feb 10, 2005 | 07:40 AM
GrandSportC3
My camera has some issues with the sound. The car is a lot louder than it seems, eventhough the new engine, which is a lot more radical than the old one, seems to be more quiet than the old one but I might be mistaken on that..
Old Feb 10, 2005 | 08:15 AM
  #33
isosceles's Avatar
isosceles
I doubt it. I think it's just your hearing starting to go south
not sure what would cause THAT
Old Feb 10, 2005 | 08:22 AM
  #34
GrandSportC3
It might be my hearing indeed
Old Feb 10, 2005 | 08:24 AM
  #35
EDDIEJ82's Avatar
EDDIEJ82
Sound good Oliver, It can't be quiter more compression = more noise. Jeez I don't see how you do it. Even with my JCL's, mines so loud I can hardly think.
Old Feb 10, 2005 | 08:57 AM
  #36
GrandSportC3
Maybe one of the neighbors secretly got into my garade and installed some mufflers
Old Feb 11, 2005 | 01:41 AM
  #37
nostgry's Avatar
nostgry
Well I don't know what GARade these kids are in but they sure butchered up your interior. You need a better alarm on your GARadge
Old Feb 11, 2005 | 02:58 AM
  #38
TruUndrtkr's Avatar
TruUndrtkr
tight lookin vette you have there...
Old Feb 11, 2005 | 08:33 AM
  #39
GrandSportC3
