Brake Lines When Caliper Removed
Old Feb 10, 2005 | 01:15 PM
72-LT1's Avatar
72-LT1
Default Brake Lines When Caliper Removed
How does everyone plug the brake lines when they remove the claipers?
Will be removing tonight and figured someone has a sure fire way to keep the fluid in and the air out.
I also havent looked at the AIM yet but will the break shields come off for replacement if you are not removing the bearings?
Thanks in Advancce
Old Feb 10, 2005 | 01:30 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Thanks in Advancce
i use the fingers off of blue latex gloves, cut and cable tied, sometimes i need a couple of them....and they do drip a little....
Old Feb 10, 2005 | 01:39 PM
Edzred72's Avatar
Edzred72
Thanks in Advancce
Spindles have to come out to remove shields.
Eddie
Solid LT1's Avatar
Solid LT1
You can buy double inverted flare fittings at a NAPA store and inverted flare plugs to make your own female plugs, for males just crimp a piece of old brake line with the flare and nut still on it and you have a "cheapie" plug. No runs, no drips, no bad paint!
Old Feb 10, 2005 | 02:02 PM
79Brian's Avatar
79Brian
I usually just use a piece of coat hanger to tie them up some where. I really don't care about the air getting in since your going to have to bleed the system anyway.
Old Feb 10, 2005 | 04:09 PM
72-LT1's Avatar
72-LT1
Eddie
The spindles are the whole bearing assembly correct?
Old Feb 10, 2005 | 04:36 PM
Tom454's Avatar
Tom454
Rear Spindle is the shaft & flange that the bearings support.... wheel attaches to the flange, a splined yoke attaches to the inner end, driven by the half-shaft via u-joints.
Ditto on the NAPA fittings... keeps the mess to minimum... keeps the water laden air out as well.
Old Feb 10, 2005 | 05:09 PM
redc3's Avatar
redc3
why all the bother? just get a variety pack of rubber vacuum line plugs and cap off the brake line. 1.20$ at any parts store.
Old Feb 10, 2005 | 05:40 PM
carhound's Avatar
carhound
Just use a piece of vacuum hose or any type hose that fits tight on the line and screw a bolt in the other end of hose.
Old Feb 10, 2005 | 05:57 PM
Tom454's Avatar
Tom454
I have the over-kill stuff because I typically move a Vette around even if it is missing a caliper. In that case, you have to use the fittings to use the brakes. And since I have them, I always use them.
But.. yeh... cheap rubber plugs or tubing will work fine if there is a male unthreaded nipple or line sticking out that you can slip the stuff onto. Female or threaded stuff will let the fluid drip & make a mess.
Depends on where you are trying to plug... and which parts you already have removed.
Old Feb 10, 2005 | 06:54 PM
72-LT1's Avatar
72-LT1
I was thinking of the plugs, I have been using electrial wire connectors on the gas lines and they seem to work OK.
Old Feb 10, 2005 | 08:59 PM
72-LT1's Avatar
72-LT1
Nope caps didnt work. I took break line off all the way to the frame, I need to go get the rubber plugs to twist in to that bugger.
Old Feb 11, 2005 | 11:10 AM
UKPaul's Avatar
UKPaul
Call me Bubba (OI! Bubba!) but I've used plastic golf tees with good results. After breaking the connection you're going to have air in it that'll need bleeding anyway, so the plug is to stop fluid leaking out & getting all over any paint within 30' (the joys of DOT3 on the garage floor & a pet cat) & to prevent the system from draining down enough to get air in the rest of the system. Somebody told me that wooden tees are great for screwing into female threads, but I don't like the sound of that. If a piece of wood flakes off unnoticed it could cause major problems later. The plastic ones go in OK with a firm twist.
Old Feb 11, 2005 | 11:18 AM
Tom454's Avatar
Tom454
I never had any luck with the plastic or rubber "shipping" plugs... they still leak. That's why I bought the inverted flare fittings & lines as described above. They work 100% each time. I have a selection 3/16, 1/4", 5/16", 3/8" and some metric for master cylinders.
To Brake Lines When Caliper Removed
