Bronze distributor gear?
Old Feb 10, 2005 | 06:42 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Default Bronze distributor gear?
Hi all, I have a question for the members that have used bronze gears in the past... How long did the gear normally last or how often did you replace it? I installed a bronze gear last spring when I put the engine in my car and it has noticable wear with relatively little use (~200 miles).
I know that Comp Cams has a much better gear out now for roller cams, but I can't use it After I bought my bronze gear I found that my Mallory Unilite distributor has the crosspin for the gear drilled .050 offset. This was a PITA because I now had to drill a crosshole into my new gear to accommodate this and still get the relation to the teeth correct.
I would just buy a different distributor to get rid of the crosshole problem, but it drives my mechanical tachometer so I'd have to replace the tach also
Old Feb 10, 2005 | 06:57 PM
gerry72's Avatar
gerry72
That kind of wear is abnormal. I'm assuming that the reason you're using the bronze gear is because you're using a steel roller cam with a steel drive gear(otherwise, there'd be no reason to use one which you probably do know).
Did you use a moly-based assembly lube on the gear before installing the distributor? Are you using a high-pressure oil pump? Is the gear running true on the shaft?
Old Feb 10, 2005 | 07:00 PM
SmokedTires
St. Jude Donor '05
Yes I am running a steel roller cam. And yes I do have a high pressure oil pump (never thought of that). Yes the gear does run true on the shaft
I didn't put assembly lube on the gear because I thought it would be fine with all the oil.
Old Feb 10, 2005 | 07:18 PM
norvalwilhelm's Avatar
norvalwilhelm
I replaced mine yearly and they showed alot of wear each year with about 2000 miles on them.
I finally emailed comp cams with my cam part number and they said I could use a normal steel gear.
Never had a problem ever since.
What about the high prices plastic gears that George runs?? I hate the thought of all those brass shavings in the oil.
Old Feb 10, 2005 | 07:25 PM
SmokedTires
St. Jude Donor '05
My distributor shaft is drilled offset so I can't use one I don't like the idea of the bronze in the oil either.
The best thing would be if I could use the gear that came with my distributor. When I talked with Comp cams before about it, they recommended either bornze or a melonized gear which I don't know if those or available offset or not either.
Old Feb 10, 2005 | 07:32 PM
norvalwilhelm
Why would mallory drill the hole offset?? Another mistake from mallory. I hate their distributors, even though I run one. My hole was drilled off also. You would think they could jig before drilling to prevent this.
Why does the gear teeth have to be aligned on the shaft. The gear can be installed anywhere, oriented any direction.
A melonized gear is sold by GM and is only a heat treating process.
Old Feb 10, 2005 | 07:38 PM
SteveG75's Avatar
SteveG75
I have the GM melonized gear with my Crane roller. If I remeber correctly, it was about $30 at the local dealer.
Old Feb 11, 2005 | 06:59 AM
SmokedTires
St. Jude Donor '05
Norval I wasn't sure if there was a required timing alignment between the gear teeth and the position that the gear mounts on the dist shaft. I have no idea why they would do such a thing as offset drill when all the gears are offered on the centerline
Old Feb 11, 2005 | 07:12 AM
PatsLs1vette's Avatar
PatsLs1vette
I agree with norval it wont matter where its at,i also bought a melonized gear from my local chevy dealer for mine,after i wore 2 out.I havent pulled it again but havent really run it that much either.
Old Feb 11, 2005 | 07:18 AM
SmokedTires
St. Jude Donor '05
Thanks Pat, I'll look into maybe getting a melonized gear then before I drop the distributor back in
Old Feb 11, 2005 | 07:28 AM
gerry72's Avatar
gerry72
If I had to guess (and it's really not much more than that if there's no obvious mechanical defect) I'd say that not coating the gear with an assembly lube and the higher load from the HP pump are probably the problem. Essentially, I think you are seeing the results of a start up failure. I'd replace the gear and coat it with some moly assembly lube and try again. Most of the time, we do get away with just the oil that exists on the cam gear (iron cams and gears) and things are fine...as far as we know. But these are still gears we're talking about and they establish wear patterns in use and have preferred methods for initial run in. If you do some Googling, you can find some guidance on the cam gear and distributor gear relationships (new cam on old distributor, old cam on new distributor...) that may be helpful.
Old Feb 11, 2005 | 07:31 AM
Fevre's Avatar
Fevre
I ordered 2 melonized gears from GM parts direct for $51 delivered, part # 19052845.
Old Feb 11, 2005 | 07:39 AM
norvalwilhelm
Again it doesn't matter how the gear goes on the distirbutor there is NO alignement of the teeth.
Second I file a .030 groove about .030 deep in the bottom machined surface of the distributor in the direction of the cam so high pressure oil leaks out and sprays on the gear. This is standard practice for alot of race shops.
I also drill a 1/8th hole in the area between the machined surfaces on the lower part of the distributor housing , anywhere works so high pressure oil sprays inside the distributor and lubricates the lower bushing.
These two things help the gear survive and same for the lower bushing.
Old Feb 11, 2005 | 07:48 AM
PatsLs1vette
One thing i thought of is the dist. shaft diam. i know msd makes a bigger shaft,does mallory do the same thing?And gm has 2 different shaft sizes also,one for the large hei internal coil and one for the external coil hei's..427-.491 to msd's .500
Old Feb 11, 2005 | 08:46 AM
SmokedTires
St. Jude Donor '05
What do you guys think of rotating the distributor shaft 90* and drilling a new hole that's in line so that I can install one of Comp Cams polymer gears then forgetting about it ?
Old Feb 11, 2005 | 09:00 AM
norvalwilhelm
NO NO NO. Do not drill the distributor shaft. It will break. Drill the gear. It has enough beef that it will cause no problems.
Keep in mind my advice on filling a small groove in the out case of the distributor to spray/leak a little oil on the gear. You have a high pressure pump and a little leaking oil won't matter to the pressure. It does keep the gear oiled. Talk to George on this.
Old Feb 11, 2005 | 09:29 AM
gkull's Avatar
gkull
Mike - The poly carbon gears are brittle, but not drill proof. I would not drill it at home. I would take it to a machine shop and have them jig it up on a verticle mill.
For that matter Norval what if Mike just cut and polished of the ends of the incorrect roll pin leaving it in the shaft and drilled 90 degrees on center. It's not like the shaft is subjected to that much load even with the tach drive.
The other thing is why don't you just call Mallory and ask them about your flaw and see if you can get a new shaft. They recourve my distributers for free. They are about a 1/2 hour from my house.
They were bought out by Mr. Gasket.
Hours: 8:30 a.m. and 5:00 p.m. Mon.-Fri. PST
Phone: 775.882.1622
Address:
Erson Technical Service
Mr. Gasket Performance Group
550 Mallory Way
Carson City, NV 89701
To Bronze distributor gear?
Old Feb 11, 2005 | 10:35 AM
Fevre's Avatar
Fevre
You are correct, I have a set of the larger ones also because I did not know GM offered 2 sizes. :o
Old Feb 11, 2005 | 11:01 AM
Ironcross's Avatar
Ironcross
Not all camshafts require one, check with the manufacturer of the cam.
Old Feb 11, 2005 | 08:09 PM
SmokedTires
St. Jude Donor '05
OK so I won't crossdrill the shaft then. I'll contact Mallory to see if I can send my distributor back to have a shaft that's drilled on center install (thanks George ). Then I'll see about getting one of those Comp Cam gears, probably even if I do have to have it drilled.
Thanks everyone
