custom plug wires
Old Feb 11, 2005 | 09:33 AM
onaqwst's Avatar
onaqwst
Default custom plug wires
i am looking for a good set of plug wires that i can cut to length. i have seen a few sets but would like some links/feedbacks on what everyone else is using...... i'm looking for a blue set......... also a nice set of wire hold downs would be nice too..
b
Old Feb 11, 2005 | 09:38 AM
LIQUIDDRAGON's Avatar
LIQUIDDRAGON
not trying to hijack your thread but i was about to post the same question and didnt want two of the same thread. the only question that i would like to add is i am looking to run 10mm+ wires and was wanting to know if anyone knows of hold downs/wire looms that work for wires this large. i want to run them next to the valve covers not under the headers. TIA
mike
Old Feb 11, 2005 | 09:39 AM
LOTAHP's Avatar
LOTAHP
These are nice
And work good toooo !!!
Old Feb 11, 2005 | 09:50 AM
onaqwst's Avatar
onaqwst
link that lota.....or give a spec..... i wouldn't mine running a larger wire than the norm.....any draw backs on larger wires if i have a sb with some minor mods.....cam,valves,ported,headers
b
Old Feb 11, 2005 | 09:59 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
I went with "over the valve cover MSD 8.5 wires" and they are really nice.....I used Moroso wire looms and MSD seperators..... now I saw at the speed shop a complete set of Moroso spark plug wires and looms and distributor cap that is really nice looking. Just remember that where you have the number 1 sparkplug wire on the distributor will determine if the custom sets fit well or not....i had to have one shorter wire made to make mine fit right...not a problem but something to consider and as you can see that for the number 8 plug wire i almost need to get a shorter one for there also...
[IMG][/IMG]
heres the Moroso link
http://www.moroso.com/catalog/catego...?catcode=40009
Old Feb 11, 2005 | 10:05 AM
big632's Avatar
big632
Originally Posted by LOTAHP
These are nice
my favorites and I have burned up just about everybody else. The best wires I have used on my engine .Maybe rick would give everyone a group purchase price?I would buy an extra set just to have around.
Old Feb 11, 2005 | 12:57 PM
markdtn's Avatar
markdtn
I have had good luck with Blue Max too. Summit list 3 universal sets as MOR-73800, 1, and 2. With 90 deg, straight, and 135 deg boots respectively.
Old Feb 11, 2005 | 01:15 PM
Gordonm's Avatar
Gordonm
These are nice
Been on my car for years and the ylook great and still work fine
Old Feb 11, 2005 | 01:26 PM
LOTAHP's Avatar
LOTAHP
At a good price I'll take 2 sets (inventory ) !!!
Old Feb 11, 2005 | 02:26 PM
JohnD77's Avatar
JohnD77
Hi guys. I know that this isn't that important but do these wires minimize radio interference or is it just a fact of Corvette life? I'm not planning to use any stock sheilding either. Thanks JD
Old Feb 11, 2005 | 02:31 PM
greyghost79's Avatar
greyghost79
i use the Moroso Blue Max wires and love them. anybody have any experience with some of the real low resistance wires. Moroso makes some "racing" wire with about 40 ohms/ft i think. MSD does too. are these worth it for street use or are you buying problems with radio interference if you go to them? are the performance gains noticeable.
Old Feb 11, 2005 | 05:47 PM
onaqwst's Avatar
onaqwst
to reduce the radio interferance, ground the radio in two spots with a larger gauge wire than the hot wire...... it'll help
b
Old Feb 11, 2005 | 06:11 PM
82Vette'ster's Avatar
82Vette'ster
I put in a set, might have been blue max, where one end is factory crimped and the other you do yourself. Use your ohm meter and check the wires befor starting. I had to redo one of the factor ends, they had broke the spiral wire when they crimped it.
The spiral wound wires are pretty good with the radio, I like them.
Old Feb 11, 2005 | 06:15 PM
redc3's Avatar
redc3
i use and believe the msd wires are the best right now
Old Feb 11, 2005 | 06:26 PM
Paul @ Thunder's Avatar
Paul @ Thunder
I'll probably be doing my custom MSD wires and Made For You looms this weekend. I'll try and post some pics. Wish my Crane XR-i would have come in this week though.
Old Feb 11, 2005 | 06:34 PM
73jst4fun's Avatar
73jst4fun
MSD 8.5 wires, separators, and looms working fine here.....
Old Feb 11, 2005 | 07:52 PM
bobs77vet's Avatar
bobs77vet
i like the way you think......
Old Feb 11, 2005 | 09:12 PM
73jst4fun's Avatar
73jst4fun
It's a Shore thing Bob.....
To custom plug wires
