Jack up the car and put jack stands under the frome
Remove the driveshaft
Remove the shifting likeage
remove the bolts from the rear tranny mount
place a support under the bellhousing after you elevate the motor, about an inch
Remove the 4 transmission bolts
Remove the Transmission
Replace the throwout bearing
Oh one more thing, you may have to remove the left header pipe, and don't forget to undo the speedo cable and back up light connection
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
I agree with GDaina but I think he missed one step.
Between Remove transmission bolts and Remove transmission, you may have to roll the transmission upside down before it will slip out. It requires all of the room you can get and this helps. Jim
I never had to do that...maybe cause I removed the left header pipe, duuno...I remember...I rocked it once or twice then it came straight out....
