Anyone use the birdcage replacement pieces for the rockers
and kick up areas? I see from the vendors it looks like you can buy
"reinforcements" or a whole new pieces to weld in. Anyone use either of these and whats the difference? I don't have any holes in my rocker pieces, just alot of rust. It may clean up good enough to POR, not sure yet. Just doing my research here. Thanks.
There are channels that are intended to be used as inserts which leaves the rusty metal on the body, there are also replacements which are what I used. Do you have the body off the frame? If the channels are still solid I would try cleaning them up like you said. If they don't clean up, I would not hesitate to replace them.
mine were gone ,so we welded in the aftermarket inserts,-a rocker channel repair from a company called ''caledonia classic cars''1968-1982 rocker channel repair
From: Las Vegas - Just stop perpetuating myths please.
The timing to replace them is now.
Originally Posted by jacobsed
Yes, the body is off the frame. How hard is it to put in new channels?
I have a cutting wheel and a mig welder.
Search for redwingvette and his website. He has a listing of how he did his. Or maybe contact him about this. But it sounds like your in the right position to replace them now and have the right equipment too.
Just my 2 cents but if the old pieces are questionble now that the body is off is the best timing to do that replacement.
Good luck and post ur results. cardo0
