I'm using a stainless steel flex fan on my 77 and do not have any cooling problems but should I switch back to the stock clutch/steel fan?The stock fan was not on the car when purchased and I have no problem buying a new stock clutch/steel fan. So what are you guys using,any pros or cons on one over the other?
John, It's funny you asked. I just took off my clutch fan and replaced it with a flix fan. My last engine I had cooling problems so I installed an electric pusher fan. I didn't remove it when I installed a ZZ4 385 hp create engine. So on the 3rd of Feb. the installation was complete. Went to the Corvette Challenge at Moroso in West Plam Beach, Fl. Second pass the engine twisted and that flix fan just chewed up the top side of my fan shroud. I'm going to leave it on because It won't cut anymore And the Chrome Flix Fan loooooooks Grrrrrrate. It's always your choise. What you want. What you really really want!!!
The flex fans have been known to come apart and they do use more power to turn than a clutch fan. I'd use the clutch fan or an electric,
Do a search on flex fan. Car Craft did an article a few years back and I posted the results a few months ago again. The HP drain is more than a few ponies. I have electric on mine, and that's what I'd do again.
I installed dual electric fans om my '79 and they work great! I wouldn't go back to the clutch fan. The electric ones cool better and do not rob horsepower! Your choice.
Bernie
Nice things about electric fans is that you if you are working on the car with the engine running (i.e. tuning), there is no danger of losing fingers, etc.
