MSD (tach ?)
Old Feb 13, 2005 | 10:02 AM
KW's Avatar
KW
Default MSD (tach ?)
Just installel a MSD system
eveything works great except my tach
cannot find any mistakes in install
open for sugestions
Thanks Kevin
Old Feb 13, 2005 | 10:21 AM
panchop's Avatar
panchop
if it's a mech tach did you put in the adapter that came in the bag?
Old Feb 13, 2005 | 03:20 PM
greyghost79's Avatar
greyghost79
give us some details. year vette? type distributor? model MSD unit?
Old Feb 13, 2005 | 05:28 PM
isosceles's Avatar
isosceles
if it's a 6AL and your tach is electric, use the tach output on the box. I tried the old "negative side of the coil" trick and the tach would not work.
Old Feb 13, 2005 | 05:55 PM
Keno's 69's Avatar
Keno's 69
I had the same problem, my cable was too long going into tack drive.
You don't want too much cable going in.
Worked for me anyway.
good luck
Old Feb 13, 2005 | 09:07 PM
KW's Avatar
KW
It was the adapter
Thanks Panchop
it is one bad ride
To MSD (tach ?)
