Rear End Housing replacement
Old Feb 13, 2005 | 02:36 PM
02dakota's Avatar
02dakota
5th Gear
Default Rear End Housing replacement
What is the best way to replace the rear end housing on a C-3?
Old Feb 13, 2005 | 05:23 PM
Gordonm's Avatar
Gordonm
Just the housing or the whole pumpkin. If you are replacing just the housing you have to set up the gears as each housing will be slightly different.
Old Feb 13, 2005 | 09:44 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
What are you trying to do??
To Rear End Housing replacement
