tubbing a C3
Old Feb 13, 2005 | 07:35 PM
panchop's Avatar
panchop
Default tubbing a C3
as i try to figure how to tub my 75 i see that the back window and deck are going to limit me somewhat. anyone have any experiance here they can share with me. i would like to get a 31 x 17 inch tire under there but i think it's gonna be tough.
thanks
greg
Old Feb 16, 2005 | 07:46 PM
AGVI's Avatar
AGVI
Canadian Events Coordinator
ttt
Old Feb 16, 2005 | 08:03 PM
hubes's Avatar
hubes
Im not positive, but from what Ive read i believe the frame gets in the way before the inner fenders
Old Feb 16, 2005 | 08:14 PM
Glensgages's Avatar
Glensgages
Altho I have no personal knowledge, a guy in my home-town back-halved his '72 (short-window/flat-deck) 25+ years ago, and other have done it since.
Old Feb 16, 2005 | 08:26 PM
cruzzin-style's Avatar
cruzzin-style
thanks
greg
Hey, my kinda Vette. Tubbed! Well, to do this job properly & the only way I've ever seen it done, is to go to a straight axle (lose the independent rear). You'll also have to fabricate a 4-link rear & most likely go to coil overs. The rear window shouldn't be an issue, but you'll have to "hack up" the storage area behind the seats, & you'll also have to lose the stock gas tank & go to a fuel cell in order to fit the "tubs". It takes alot of good old fabrication to do all of this. Most likely, you'd be better doing it "body-off" too. Don't know about the 31 tall tires either, but "stuffing" the rear with the largest tires possible back there will look "cool" no matter what. Good luck with your project.
Old Feb 16, 2005 | 08:34 PM
Glensgages's Avatar
Glensgages
Originally Posted by cruzzin-style
The rear window shouldn't be an issue..... Don't know about the 31 tall tires either, but "stuffing" the rear with the largest tires possible back there will look "cool" no matter what.
I think the short-window/flat-deck C3s present problems with the diagonal bars, running from the rear on the main hoop, to the rear area (bumper?) of the frame-rails:
on pre-'78 Corvettes, this bar is mounted much-lower on the main hoop, to clear the flat deck
(which I'd taken a picture of the local guy's '72 way-back-when...)
I'm 'guessing' he ran 32" x 14"s, too.....
Old Feb 16, 2005 | 09:59 PM
cruzzin-style
Forget The stock frame rails. You'll have to fabricate a 4-link rear. It has been done. If I can find some of the old pics I have of this set-up, i'll post 'em.
Old Feb 17, 2005 | 05:23 AM
Glensgages's Avatar
Glensgages
I know exactly what you are talking about:
I've raced against a few of these type Corvettes, and am planning-on building my old '80 into just such a car.
The short-window/flat-deck cars limit where the diagonal-bar, from the top of the main hoop to the rear of the car, can be located (I think I've even seen a few that have these bars pass THRU the window, 'notch' the deck, and the bars go back-THRU the deck.....WAY-'Bubba'), regardless of using stock frame rails or narrowed frame-rails.
The problem is a 'horizontal'-issue, and has nothing to do with the width of frame-rails:
'78-up Corvettes offer more room for these bars to be located.
Old Feb 17, 2005 | 08:00 AM
big632's Avatar
big632
You dont use a diagonal bar on top. You use a panard bar or a wishbone track locater. As I have repeatedly said before it is no problem to do any vette. I have done midyears c4s c3s year makes little diff.You can also do it with or without a cage depending on what you are going to do. I use a 2x4 clip which allows complete safety on high hp cars without a cage.Sanctionig bodies require cages so those are done too.I prefer a cage. The only way I do them is to cut the car in half,any other way is half-***.That way my new clip is jig welded put in place welded up to the car and squared to 1/16th diagonally to the front ball joints and straighter than it left the factory.Your new car will drive better than it ever did and you can put as little or big a tire as you want. 32x 16 slicks or 32x17.5 et streets are what I run.A back half will drop your weight app 300lbs with lighter components.200 minimum even with no aluminum.Such as center section and brakes.
Old Feb 17, 2005 | 08:55 AM
panchop's Avatar
panchop
i am going to back half it, sorry thought that was a given with the tubbs. Just looking at the body it seemed like i was going to either run out of room under there or have to sit the body up higher then stock. could be i'm mistaken.
Old Feb 17, 2005 | 09:11 AM
big632's Avatar
big632
You will need to be higher than stock with the tall tires but they will be inboard a little.If you slam it down you can use a much stiffer coil spring to tighten the suspension from bottoming out your tires if you like that look. You can give yourself about 3inches either way factored in when you put it together.
Old Feb 17, 2005 | 02:59 PM
Glensgages's Avatar
Glensgages
big632:
If you click this link.....
http://www.swracecars.com/roll_bars.asp
Unless I'm missing the obvious, I'd think the two diagonal bars, from the top of the main hoop, to the rear of the car (rear wheel tubs?), in either 8-point bar, or 10-point cage, would not clear the short-window/low-deck of a pre-'78 Corvette:
oddly, S&W offers the same bar/cage package for ALL C3s.....
Old Feb 17, 2005 | 03:19 PM
Twin_Turbo's Avatar
Twin_Turbo
if panchop wanted a cage he should not have let mine leave his garage LOL, that was a 12 pnt S&W cage
Old Feb 17, 2005 | 04:05 PM
big632's Avatar
big632
big632:
Yes they clear.they are much shorter than you think. I was talking about a diagonal link on the rear end used like a track locator.
Old Feb 17, 2005 | 04:23 PM
Glensgages's Avatar
Glensgages
Naw:
was talking-about bars in the cage all the time!
Old Feb 17, 2005 | 11:21 PM
panchop's Avatar
panchop
hope it has arrived safley, i was thinking about that. could have used it like a jig. oh well. LOL
Old Feb 18, 2005 | 03:38 AM
Twin_Turbo's Avatar
Twin_Turbo
it's still in the container, takes a month or so..so should be here in the next couple of weeks
Yeah, you could have at least taken measurements off it and have a local shop bend a copy of it.
Old Jul 27, 2014 | 06:26 PM
malibu1981's Avatar
malibu1981
1st Gear
By any chance do you have any photo's of the c3 already tubed
To tubbing a C3
