Is it OK to.........
Old Feb 13, 2005 | 08:37 PM
David Ey's Avatar
David Ey
Default Is it OK to.........
jack up the rear under the spring and sloooooooly spin the wheels with the engine to listen for noises?
Old Feb 13, 2005 | 08:43 PM
Retro78's Avatar
Retro78
no, the angle of the U joints is too much. Although I have done this by supporting the rear under the trailing arms with jack stands to compress the sping and reduce the angle. Still can be dangerous for both you and car...carefull.
Old Feb 13, 2005 | 08:46 PM
page62's Avatar
page62
But it is okay to jack up the car under the spring, carefully, of course...just not for the purpose you were thinking of!
Old Feb 13, 2005 | 09:01 PM
ddecart's Avatar
ddecart
SPARTAN
CI 3-4-5-6-8-9-10 Vet
CI-9 AutoX Winner
CI-3 Go Kart Champ
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11
I would not run my car if it's only on a jack. Jackstands under the frame are a requirement if that engine is to be run.
Old Feb 13, 2005 | 09:03 PM
70 LS1's Avatar
70 LS1
Its fine. I've done it before, but I had the car on jackstands. Just let the car idle.
Old Feb 13, 2005 | 09:05 PM
page62's Avatar
page62
What is the noise? Is it perhaps a knocking sound when you make a tight turn at slow speed...?
Old Feb 13, 2005 | 09:09 PM
David Ey's Avatar
David Ey
It sounds like the right rear wheel bearing but it could be a diff. bearing.
My wheels lean in a bit too.
Old Feb 13, 2005 | 09:28 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Check if the U-joint bolts hit the differential - that's what mine did when I bought the car ... the rear tires were leaning in because of worn bushings (all bushings) ...
Old Feb 13, 2005 | 09:32 PM
David Ey's Avatar
David Ey
OK, thanks folks. I appreciate the response.
Old Feb 13, 2005 | 09:41 PM
Retro78's Avatar
Retro78
Redbad79... just saw your before and after pics. Wow....you sure brought your vette a long way. Nice work!!! Sounds from your description that your side yokes may have been worn...causing the wheel alignment and U-bolt clearance issue.
Old Feb 13, 2005 | 09:52 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Everything was worn, especially the strut rod bushings... and the trailing arms bushings... that was bad enough to allow the wheels to lean inwards at the top - this pushed the half shafts inwards and the U-joint bolts hit the the 'pumpkin'
The yokes got "machined" as well..... ...
To Is it OK to.........
