First engine start...
Old Feb 13, 2005 | 10:43 PM
Jclgodale3's Avatar
Jclgodale3
Default First engine start...
Well...after roughly a month the engine was ready to start. Had to be a bit creative with the wiring and air flow but after setting the distributor and ensuring gas flow...it fired on the first shot with a remote starter. Here's a few pictures of the start up...
A big THANKS goes to a couple great friends...BP and VettePilot68 from here on the forum. Thanks guys! Now for the T5!
Old Feb 13, 2005 | 10:46 PM
topless68's Avatar
topless68
Looks good...
Old Feb 13, 2005 | 10:47 PM
Glassbowtie77's Avatar
Glassbowtie77
Very ,can't wait to be able to start mine up.
Old Feb 13, 2005 | 10:50 PM
Jclgodale3's Avatar
Jclgodale3
oh...it showed almost 80lbs of oil pressure at startup...consistant 60lbs at 2000 rpm and about 28-30lbs at idle...
Old Feb 13, 2005 | 11:01 PM
Ex_F-Body_Enthusiast's Avatar
Congrats! Good to see that you had a fire extinguisher handy!
Old Feb 13, 2005 | 11:51 PM
yellovette's Avatar
yellovette
Congrats! Is that a 4 X 4 tranny?
Old Feb 13, 2005 | 11:56 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Old Feb 14, 2005 | 12:02 AM
Jclgodale3's Avatar
Jclgodale3
yep, well er...sorta. I heard the 4x4 tranny conversion is the way to go for solid launches
Actually...just didn't want the engine "leaning" on the motor mounts so rigged that up for support...
Old Feb 14, 2005 | 08:53 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Dayum!!! You are making some kind of progress. I have been watching your posts and you seem to be moving right along at a pretty good pace. It is going to be a sweet ride when you get it all put together again. Keep on posting pics.
Old Feb 14, 2005 | 02:33 PM
Jclgodale3's Avatar
Jclgodale3
[QUOTE=Eddie 70]Dayum!!! You are making some kind of progress.
Eddie...I just hate the idea of not doing "something" even if it's not major. While waiting on the engine block to come back from the machine shop, I took a tap and die set and cleaned out all the mounting nuts, plates etc on the frame and supports...kept me occupied. With the help on this forum...things just seem to slide right along!
Thanks again to James K!
Old Feb 14, 2005 | 07:03 PM
Jclgodale3's Avatar
Jclgodale3
are the pics showing now JK?
To First engine start...
