Quart Can v. Spray Bottle
Old Feb 14, 2005 | 01:08 PM
mvftw's Avatar
mvftw
Default Quart Can v. Spray Bottle
How many 16oz. spray bottles would equal a quart can...I want to touch some of my interior...
Old Feb 14, 2005 | 02:17 PM
mandm1200's Avatar
mandm1200
Have you tried to call the vendor who you are planning on buying from? The obvious answer would be 2, but the sprays cans/bottles are thinned and have propellant in them reducing the amount of actual paint/dye. So it will take a few more than 2.
Old Feb 14, 2005 | 02:18 PM
DropTopBigBlock's Avatar
DropTopBigBlock
32 oz in a quart.
Old Feb 14, 2005 | 02:19 PM
jerryjfunk's Avatar
jerryjfunk
I did my entire interior with a quart and a half, if that helps.
Old Feb 14, 2005 | 02:26 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you are lucky if there is 3-4 Fluid Ounces in a spray can....so it will take 8 spray cans to equal 1 fluid qt.
Old Feb 14, 2005 | 04:41 PM
mooneyd's Avatar
mooneyd
I did my whole interior, took about 7-8 cans. Make sure you get more than enough, that way they all have the same dye lot. And you will not have a problem matching the color. You will also have some left for future touch ups if needed and it will match.
Old Feb 14, 2005 | 08:08 PM
mvftw's Avatar
mvftw
I'm planning on using the Preval system. A few members mentioned it on this site. If I get the quart it's cheaper and has the same lot number. http://www.prevalspraygun.com/
Old Feb 14, 2005 | 08:29 PM
carl a's Avatar
carl a
i have been using prevail for a few years,, you can get them at menards a lot cheaper than they sell them in body shop /paint supply houses--i seen the re-fill cartrages fro $1.50 or $2.00-and the whole set up for $3.50 instead of the $7.50 at paint supply houses----you'll probably have to thin the paint outta the quart,,,but if you got a lot of parts to dye you'll save a lot and have it for the rest of your life!!!!
To Quart Can v. Spray Bottle
