Windshield frame corner replacement
Old Feb 14, 2005 | 01:18 PM
dans73ttop's Avatar
dans73ttop
Default Windshield frame corner replacement
I am in the process of removing the windshied frame corner. It appears that the piece was secured with adhesive and rivets. The replacement part I ordered states that welding is required. Can I install new part as the original or weld? Also, should I secure the frame in case it moves after the corner is removed.
Thanks in advance,
Dan
Old Feb 14, 2005 | 02:19 PM
72LS1Vette's Avatar
72LS1Vette
I could be wrong but I don't think the original corner was fastened with adhesive and rivets since the frame is a structural component. More likely the corner was rusted and Bubba glued a new one on.
If the body is on the frame I don't think the windshield frame is going to move when you remove the corner. If the frame was under tension you would probably have a broken windshield.
Rick B.
Old Feb 14, 2005 | 03:08 PM
dans73ttop's Avatar
dans73ttop
Rick,
I would tend to agree with you, except both corners are constructed the same way.
Do you think welding is the only correct method of attachment/
Old Feb 14, 2005 | 03:10 PM
70vert's Avatar
70vert
Banned Scam/Spammer
There are no rivits or adhesive holding the windsheild together (or at least there's not suppose to be).
Old Feb 14, 2005 | 03:28 PM
Red 69's Avatar
Red 69
The windshield frame pieces were spot welded from the factory.
Old Feb 14, 2005 | 03:39 PM
NHvette's Avatar
NHvette
Yes, welding it is the only correct way.
The only safe way, IMO. Have someone weld it.
Old Feb 14, 2005 | 06:23 PM
kortensi's Avatar
kortensi
I'm about to do the same. Both sides are welded on mine.
Here is my problem child.
http://forums.corvetteforum.com/show...5&page=1&pp=20
Take some photos for us and let us know how it turns out.
KO
To Windshield frame corner replacement
