add a small rocket engine for better acceleration?
could add 1000 to 2000 pounds of thrust, mounted in the spare area. lot of fun at car shows, exhibit drags, wow friends, etc. Not to be the fastest, but
same as SPACESHIPONE
i'LL DON my FLAME suit.
a good idea as it throws a 2-3 foot flame.
I use to assemble large scale model rockets, and got my low explosives liscense so i could launch a certain size rocket engine, can't remember what, maybe H or J. Your talking something exponentially larger than that..... 1-2k lbs of thrust is a lot..... you'd be able to launch a lotus elise vertically with that much thrust
Now..... say we could get a few hundred pounds of thrust sustained for 8-10 seconds (fairly substantial amount of time), you wouldn't be able to afford doing it using premade components... it would be incredibly expensive. Now your talking making your own solid rocket fuel. Its not all that hard, but requires some hardware for mixing and heating, and you'll need lots of mix........ Ok.... so we've got a rocket engine made, now you need to fire it... You'd probably blow it up, and your car with it. So whats the alternitive..... liquid fueled rockets. Here's one for you, its a good start:http://www.total.net/~launch/ss67b2.htm This would be much more predictable and safer than the solid propellent. The problem is that for its size its gonna put out less power. The one in the link cost $900 and only sustains 57lbs of thrust for 8.5 seconds..... After reviewing all the options I'd say a 150shot from a holley kit is probably your best shot for going fast.... its your call
I'd try to think of another way of looking cool..... i hear flamethrower are in this time of year
Not that I personally would run out and do this, but it appears to be doable by an expert.
I saw it run at Baylands before they closed it. That thing would hit you in the face with a major blast of radiant heat when it took off. The noise and the flames were spectacular!
He had to shut it down at half track or he probably would have lifted off!
Really cool to see in person. -Mark.
i checked out that link!
it's good to see what we had in "the old days"Kind of like when guys with a then new 286 CPU could only dream of playing music
Searing heat and sound.
I have the utmost respect for the guys who spend everyday doing this. I only did a couple of times. Much preferred being in the jet.
THREADHIJACK - OFF.
There actually was a rocket add on that was sold in the early sixties. I saw an article about it in the past year or two in one of the hot rod mags in the vintage article section. It was called the Turbonique. Here's a couple of sites with some info.http://www.almar.easynet.be/turbonique.htm
http://www.the-rocketman.com/turbonique.html
(Just my humble opinion) It would look cool maybe
