My car has been sitting for about 45 to 60 days while I worked on some fuel issues. In the interim, I poured some Sta-bil in the gas tank.
After I fixed the fuel issue (electric fuel pump) i encountered temperature issues (temperature gauge sky-rocketed after the car warmed and was driven). I thought I traced this issue down to low fuel coolant.
So I poured a little more than a gallon in the radiator, started the car, it appeared to be the fix. Note I did not take the car out for a test drive a at this time. However, I took it out for a drive a few days later. The car started running hot again.
I immediately took the car home, as I sat in my drive way I reved the engine. Each time I did this white smoke billowed out of the exhaust.
I turned the car off then re-checked the radiator. Guess what - about another gallon low on coolant.
OK lay it on me, what do think has happened? Any connection between the white smoke and the coolant or the Sta-bil
By the way this is a relatively new engine
Thanks in advance for your advice.
Nothing to do with the Sta-bil.
Its either a cracked head or block, maybe pull the spark plugs out and read them, the bad cylinder should show on the plug.
Then you will have to pull the head to verify.
A bad head gasket would put the compression into the cooling system, intake gasket =coolant would go into the oil pan.
After pulling the plugs, reading them, bring that piston close to the top compression stroke and pressurize the cooling system, it should come out of the bad one.
Starting it with coolant in the cylinder can bend the rods.
Has it been over heated before ?
No - this is the first time. The engine always ran nice and cool. I'm currently runnning an electric water pump and an aluminum radiator with dual Spals.
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
