Oil Gauge
Old Feb 16, 2005 | 01:32 PM
71redskin's Avatar
71redskin
Default Oil Gauge
my oil gauge wasn't working so i ordered and installed new oil line kit and soaked old fittings in paint thinner...after hooking up the new lines the oil gauge needle seems to be stuck. is there any way to free the needle or is it easier to replace the gauge
Old Feb 16, 2005 | 02:09 PM
Gordonm's Avatar
Gordonm
I have had the same problem. Isprayed the back and the oil hole with brake clean until it ran clear. This worked for about 1 year. I did this twice. I currently have a new one that will be going in.
Old Feb 16, 2005 | 03:16 PM
James1970's Avatar
James1970
I ordered a new one for my 70' a couple of weeks ago from CC.
After removing the inoperative gauge, I turned the engine over to verify oil flow (I was ready with a rag) through the brass line (oil flowed freely). I then reinstalled the gauge just to see if it would work. Still no good.
Therefore, I assume the gauge is the problem. Ordered new guage and 90 degree attach bolt. Hope they work....
Old Feb 16, 2005 | 06:41 PM
71redskin's Avatar
71redskin
Default oil gauge
sounds like i might as well look for a new gauge...no sense in putting the dash back together until then... plus its starting to warm up a little in these here parts...gotta hurry
To Oil Gauge
