Tire size questions...HELP!
Old Feb 17, 2005 | 02:11 PM
bryan27's Avatar
bryan27
Default Tire size questions...HELP!
Okay, I just bought my "jump on the bandwagon" 17x8, 4 inch backspacing, (regular trailing arms) TTIIs, and it is time to order tires.
Question 1: What sidewall height means that I do not have to recalibrate my speedometer 45 or 50?
Question 2: What is the fattest tire width that I can get on my rear wheels without a problem and without modification?
Question 3: What is the fattest tire width that I can get on the front wheels and not have a rub when I turn (without any modification)?
Question 4: Someone once mentioned to me a long time ago that the factory used to shave a little of the wheel well out to get fatter tires on the front in some models...is this true? If I am willing to give my wheel wells a little trim, how wide can I go then?
Thanks guys,
Bryan
Old Feb 17, 2005 | 02:26 PM
81corvettevortec's Avatar
81corvettevortec
if all my rims were the same width, and at 8 inches wide you can't go with that wide of tire! i would recommend going with 255/45's all the way around! if you went with a 50 series tire it would be closer to your origonal tire height.
Ryan.
PS- nice choose on wheels. the TT2's are classic!
Old Feb 17, 2005 | 02:57 PM
lvrpool32's Avatar
lvrpool32
On 17 x 8's the closest to the original rolling radius is a 255/50/17 (27").
Issues with that size is that a) theres not THAT many choices in that size and if you ever decide to go to larger in the rear there isnt a wider tire (say 285/40) that would be the same rolling radius. b) 255/50's can rub on full lock.
On mine I am using 255/45/17's on the front, they are closer to 26" rolling radius and you may have to lower the car to reduce the tire to fender gap.
Its basically upto those 2 sizes.
Nick.
Old Feb 17, 2005 | 02:58 PM
70 LS1's Avatar
70 LS1
255/50/17 is about as close to stock diameter you are going to get. They will fill up the wheel well nicely. I have 245/45 17 on the front and they are a little short.
Old Feb 17, 2005 | 03:19 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
There have been one or two here who said 50s rubbed, so I went with 255/45/17 all around.
Old Feb 17, 2005 | 05:32 PM
Gordonm's Avatar
Gordonm
I tried 255 50 17s and they rubbed. I am running 255 45 17s now and they fit fine and no rubbing.
Old Feb 17, 2005 | 07:57 PM
bryan27's Avatar
bryan27
okay guys, now what about the diference between 245s and 255s?
Also, how far off is the speedometer if I switch to 45s instead of 50s?
Old Feb 17, 2005 | 08:45 PM
Gordonm's Avatar
Gordonm
http://www.miata.net/garage/tirecalc.html
Try this site. You can plug in different sizes and compare them.
To Tire size questions...HELP!
