closed chamber VS. open chamber ???????
Old Feb 17, 2005 | 05:11 PM
72LS5's Avatar
72LS5
Default closed chamber VS. open chamber ???????
I'm putting the original BB back into my car. The heads that I have to put on it are 3964290s, they are closed chambered and dated K 15 9 and K 5 9. So, I assuming that they are 69 heads and not true to my car I can live with that. OK to the question ...... I hear talk about open chamber flowing better than closed chamber. Which is better and would these heads perform well in my car?
Old Feb 17, 2005 | 05:17 PM
GDaina's Avatar
GDaina
Open chamber, by far are better, cleaner burning.....
Old Feb 17, 2005 | 05:27 PM
norvalwilhelm's Avatar
norvalwilhelm
They were invented to produce less emission true but your motor will put out more horsepower with closed chamber because of the increased compression. Open chamber lower a compression ratio and I have seen a magaizine test where 4 sets of heads were prepared and bolted on the test mule. The closed chamber rectangular port won the shootout over the other 3.
The block was kept consistant and only the heads were changed.
Old Feb 17, 2005 | 05:34 PM
Gage's Avatar
Gage
Stick with the closed chamber. If you had open chambered heads, you could get larger dome pistons to make up the lost compression. That would be the ideal scenario; better flow, lower emissions, high compression.
Old Feb 17, 2005 | 05:44 PM
GDaina's Avatar
GDaina
Open chamber heads lose 2 points in c.r. vs. close chamber heads..
That test is not valid...assuming 11:0 closed chamber pistons were run, that means when the open chamber heads were used, the c.r. was 9:1. If you run identical C.R. with both sets of heads, the Open Chamber will win, hands down...it's in the spark travel...the open chamber heads...the spark is unshrouded....cleaner burning, less emmissions...more power.....
Old Feb 18, 2005 | 09:24 AM
Ironcross's Avatar
Ironcross
I can buy this, but the pistons would also have to be changed to match the heads. With out a piston change the open chambered heads will lose because of the larger volumn when used with closed chamber piston equiped engines.
Old Feb 18, 2005 | 12:09 PM
LemansBlue68's Avatar
LemansBlue68
Data talks!
http://www.chevyhiperformance.com/te...98/index8.html
Old Feb 18, 2005 | 01:33 PM
Ironcross's Avatar
Ironcross
Originally Posted by LemansBlue68
What should I be looking for, except that I dont use any of them. All mine are rectangular port heads in both my closed and open chamber engines.
Old Feb 19, 2005 | 08:00 PM
LemansBlue68
The CHP data base has a section on rectangular heads too. All different port sizes chamber sizes etc. Small block cylinder head section too. Pretty good comparisons for flow numbers.
To closed chamber VS. open chamber ???????
