Edelbrock Air Cleaners
Old Feb 18, 2005 | 10:36 AM
Garys 68's Avatar
Garys 68
Default Edelbrock Air Cleaners
Anyone using one an Edelbrock Pro Flo cleaner (Summit, EDL-1002)? Any pros/cons to using one? Is there a provision for PCV hookup?
Gary
http://store.summitracing.com/defaul...=egnsearch.asp
Old Feb 18, 2005 | 10:48 AM
SteveG75's Avatar
SteveG75
Con. Foam melts if you have a carb backfire.
Old Feb 18, 2005 | 12:12 PM
PRNDL's Avatar
PRNDL
Originally Posted by Garys 68
con = less hood clearance than stock dropdown base + air cleaner!!
I bought one and can't use it.
Old Feb 18, 2005 | 12:34 PM
Garys 68's Avatar
Garys 68
I've got an L88 hood, so clearace isn't a problem.
Gary
Old Feb 18, 2005 | 02:45 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
I feel the same way about the K&N Extreme top lid.
Also with those ProFlows, you need a bunch of clearance to the hood because of any sharp air flow angle/turn creates too much turbulence and sloppy metering.
Old Feb 18, 2005 | 06:07 PM
Jason Staley's Avatar
Jason Staley
Had one on my big block Olds until it backfired and caught this type of air cleaner on fire and melted the foam. Spent the rest of the day cleaning out the carb. Not fun.....Now I have a K&N filter on it...much better.
To Edelbrock Air Cleaners
