Just installed 10" C4 spring bolts
Old Feb 18, 2005 | 08:21 PM
LFZ's Avatar
LFZ
Default Just installed 10" C4 spring bolts
I should have got these a long time ago, instead of buying the 8 inchers..these things really dropped the rear to match the front nicely.
Old Feb 18, 2005 | 09:05 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Are you using the 10" bolts with the stock rims and no clearance problems?
Old Feb 18, 2005 | 09:15 PM
LFZ's Avatar
LFZ
17s right now..i'll be putting the 15s back on tomorrow, because i got to take it to the alignment shop next week. Still looks like theres enough clearance though..i'm running a 7 leaf steel spring.
Old Feb 18, 2005 | 09:23 PM
bbeck's Avatar
bbeck
any pics?
Old Feb 18, 2005 | 09:57 PM
LFZ's Avatar
LFZ
I still got to go down some, and i have plenty of room for adjustment. my front fender sits at 26" and back sits at 27.25"..i think i need to bring the back down to 27" to get a good even spread between the front and rear. Not a good pic..its night and not very good lightening in my garage.
Old Feb 18, 2005 | 10:01 PM
kdf1986's Avatar
kdf1986
I would say that the lighting in your garage is good enough to showw off your car!
69 vert with sidepipes and some chrome rims.....NICE!
kdf
Old Feb 18, 2005 | 10:17 PM
bbeck's Avatar
bbeck
nice, where'd you get the bolts?
Old Feb 18, 2005 | 11:01 PM
LFZ's Avatar
LFZ
Ecklers
Old Feb 18, 2005 | 11:07 PM
bbeck's Avatar
bbeck
let us know how it fits with the 15 inch tires back on
Old Feb 18, 2005 | 11:08 PM
LFZ's Avatar
LFZ
will do
Old Feb 18, 2005 | 11:16 PM
72LS1Vette's Avatar
72LS1Vette
If you are planning on using 17's wouldn't it be better to have it aligned with the wheel/tire combo you are planning to drive on?
Rick B.
Old Feb 18, 2005 | 11:32 PM
72LS1Vette's Avatar
72LS1Vette
If you have room in in your garage for a car AND a chair I'm envious!
Rick B.
Old Feb 19, 2005 | 12:06 AM
68/70Vette's Avatar
68/70Vette
There's another similar posting on the C3 forum. I'd just like to add my opinion as stated on the other posting. (Hopefully I'm not getting to be too much of a boor here.) All this stuff about body height/ground clearance should have statements related to the suspension geometry. Basically stated, ---I think this is correct, is that the half shafts should be parallel to the ground with a driver and a representative fuel load in the car. My experience with 225/R50X17 tires on my 1968 Corvette with a 360# VBP spring is that the car is really low and the half shafts are parallel to the ground (Well my 10 inch bolts will need to be adjusted to ~9.5 inches to get the half shafts parallel.) I have 550 # springs in the front. I'll lhave to wait until I get the engine in to see what I have to do to trim these springs (if anything.)
..............Bottom Line. Do try to lower the car as much as possible. But do make sure the half axles are parallel to the ground when you're finished. My opinion.
Old Feb 19, 2005 | 01:03 AM
LFZ's Avatar
LFZ
Rick B.
shouldn't make a difference..my alignement is so out of wack, i dont want to risk putting any wear spots on my new 17 inch tires...i'd rather just drive 27 miles to the alignment shop on my old 15s...if that makes sense.
Old Feb 19, 2005 | 08:23 AM
djcwardog's Avatar
djcwardog
Would 27 miles really cause a problem on the 17" tires? I would really want it all set up the way you will drive it - meaning that it be aligned with the 17's on it. Also, get the ride height correct before you spend money on the alignment. JMHO...
Old Feb 19, 2005 | 09:35 AM
mandm1200's Avatar
mandm1200
Rick B.
The tire/wheel combo should have a minimal affect if the diameter of the tires are close to each other. A full tank of gas versus an empty tank would probably affect the alignment more.
Old Feb 19, 2005 | 01:12 PM
LFZ's Avatar
LFZ
good tip, i might just do that.
To Just installed 10" C4 spring bolts
Old Feb 19, 2005 | 06:23 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
After my stance was adjusted, I cut mine down to about 9 inches.
They are quite noticeable from the rear, I may paint them black or something.
Old Feb 24, 2005 | 12:56 AM
bbeck's Avatar
bbeck
I'm gonna have to get a set, my rear sits pretty high
Old Feb 24, 2005 | 07:22 AM
LFZ's Avatar
LFZ
bbeck, did you get my PM about the 15" tire clearance problems.?
