I haven't decide what to do with speakers yet. I would like to put a small amp in the back for the rear speakers that I have there now. They are 90 watt 4X10's mounted in small speaker box's on a shelf across the wheel wells.
I don't see any reason why a slight angle would cause any issues as long as I support the back of the radio to keep it from bouncing.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Bryan, looks good. I like the surround you have made for yours. Where did you get the material to make this? That is just the finishing touch I need to add to mine.
Eddie,
I got it from one of the plastic shops I deal with. I will see if I can get you the name of the supplier for you. It is gained flat stock "ABS" 1/16th" thick and comes in sheets.
