identifying rear gears
Old Feb 20, 2005 | 11:16 AM
Burgundy 69's Avatar
Burgundy 69
Default identifying rear gears
We dropped the rear end on the 69 yesterday and have the differential power washed and scrubbed. I believe I have identified the build date stamped into the pad which shows 1A0 9 26 69 W. Looks like Aug 26, 69 (my car is a Oct 69 vehicle).
There is a number cast into the rear cover 3871875 which I assume is just a casting # for that part.
There is also another number, H49, which is stamped into the diff which I hope identifies the gearing.
Can anyone confirm this and read it? Thanks
Mark
Old Feb 20, 2005 | 11:34 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
It's September 26, 69, not August.
AO code = 3.70 ratio. positraction...small block.
BTW, the "1" that precedes the AO is the shift when it was produced. The "W" stands for Warner Gear...where it was made.
Chuck
Old Feb 20, 2005 | 11:42 AM
GTR1999's Avatar
GTR1999
There's also a chance they have been replaced over the past 35 years. Count the number of rotations of the input/axles to get a rough idea if they are 370's. What was your 60 mph rpm?
Gary
Old Feb 20, 2005 | 05:50 PM
Burgundy 69
Actually, I can count. My fingers just work faster than my brain (9 = September, duh).
Thanks for the help decoding this. I suspect that this unit has never been out of the car before and the 3.70 remains.
Thanks!!!
Mark
To identifying rear gears
