pcv hookup..
Old Feb 20, 2005 | 01:02 PM
fugawi's Avatar
fugawi
Default pcv hookup..
is it better to hook the pcv. to the bottom of the air cleaner, or would it be better to hook to back of carb. (holly dbl.pumper).
Old Feb 20, 2005 | 02:23 PM
djcwardog's Avatar
djcwardog
Default Hook to Carb
You need a good strong vacuum signal to work that PCV. Find the proper port (usually a bigger diameter pipe than the other ones) on the carb and connect it up with proper hose from your PCV valve sticking up out of one of your valve covers. Mere mounting to the air cleaner base will not do it... The air cleaner base mount is for an air breather pipe (providing a filtered draw source for the suction created by the PCV valve) that comes from the other valve cover than the one that has your PCV valve stuck in it. PCV is one smog item that is great to have because it sucks air out of the inside of the block where all the spinning parts are. It reduces oil frothing, leaks, etc... Keep it functional!
Old Feb 20, 2005 | 04:11 PM
fugawi's Avatar
fugawi
ttt
Old Feb 20, 2005 | 08:41 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
The PCV needs a vacuum source to function.
Old Feb 20, 2005 | 08:48 PM
pws69's Avatar
pws69
Back of the carb. The other valve cover hose connects to the bottom of the air cleaner.
To pcv hookup..
