freshen up distributor
Old Feb 20, 2005 | 04:00 PM
jeaux's Avatar
jeaux
Default freshen up distributor
I'm thinking of rebuilding my distributor I'm looking at kits from Pertronix and Proform they both seem to offer the same stuff any one have exp. with either one
Old Feb 20, 2005 | 04:25 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have the original Pertronix Ignitor and it has been in service for over 5 years. It has worked good for me. Several folks have these in their cars.
Old Feb 20, 2005 | 04:29 PM
RHD '68 L89's Avatar
RHD '68 L89
I have been running Pertronix series 1 in both my 68 Bonneville and my Vette for many years. The Bonny was my daily driver up until recently. Both are still performing great. they will not give you a performance advantage over a set of well tuned points but they will give the same level of performance continuously once it is tuned.
Make sure you set the mechanical advance for a total of 36 deg and all in by 2500-3000 rpm. Then check the vacuum advance gives another 16 (?, Check Lars paper in Corvettefaq) degrees for cruising.
Old Feb 20, 2005 | 04:34 PM
C3 Stroker's Avatar
C3 Stroker
I used the Pertronix Ignitor for over 10 years with no problems before upgrading to HEI......never even had to open the distributor cap.
Old Feb 20, 2005 | 07:25 PM
jeaux's Avatar
jeaux
I have a HEI now and I'm gonna freshen up with a kit from Pertronix
Old Feb 21, 2005 | 02:50 AM
stingr69's Avatar
stingr69
I put the Pertronix HEI hop-up kit in my '80 distributor. The Pertronix coil was defective and would run erraticaly. I put the stock coil back in and it runs great. Aside from that problem, the recurve kit that comes with the package was one of the best I have used. The adjustable vacuum can that comes with the kit is pretty cool as well.
If I had it to do over again I would have kept the GM electronics, installed the recurve kit, the adjustable vacuum advance and the new cap and called it good.
-Mark.
To freshen up distributor
