Underbody spray/bedliner spray
Old Feb 21, 2005 | 06:47 PM
adam's Avatar
adam
Default Underbody spray/bedliner spray
I'm cleaning the rear end and was cleaning the underside
of the wheel well body.
Has anyone used any of these spray (spray paint type cans)
underbody or bedliner rubberized applications in the wheel
well?
I was thinking of just repainting with black (what's a good color/number?) but saw these sprays at AZ. They're about
the same price, but I don't recall it...
Thanks.
Old Feb 21, 2005 | 07:39 PM
ICEMAN59's Avatar
ICEMAN59
Yes I used the spray can bed liner on the undercarrige and the wheel wells. It came out great, and very durable. I'm happy with it.
Old Feb 22, 2005 | 07:42 PM
hotrodrik's Avatar
hotrodrik
Default bedliner spray
I'm working on my 77 this winter and used Duplicolor spray in bedliner on the underside & wheelwells. It works great .I've also have used it on my 40 Ford street rod , & 56 Chevy The chevy was done 4 years ago ,still looks fresh.
Old Feb 22, 2005 | 07:50 PM
jerryjfunk's Avatar
jerryjfunk
Yeah, I used rubberized undercoating in my wheel wells and it seems to be very durable and looks pretty nice, too.
Old Feb 22, 2005 | 08:07 PM
75 Hot One's Avatar
75 Hot One
I've used asphaltic spray with good success for many years. Plain asphalt seems to last longer and protect better than the ruberized sprays.
Old Feb 23, 2005 | 11:04 AM
adam's Avatar
adam
What kind of prep did you do to the underside of the body (fiberglass)
to ensure adhesion? I'm thinking of spraying it on the underside of
the compartment boxes to lessen rock noise as well.
Old Feb 23, 2005 | 11:13 AM
Madmikeee's Avatar
Madmikeee
From: Sometimes I wonder... why is that frisbee getting bigger? Then it hits me.
Cruise-In X Veteran
St. Jude Donor '06
You'd probably want to take a pressure washer to the areas you plan on spraying and then hit it with some scotch pads and degreaser , other than that the spray you are talking about pretty much sticks to everything and anything.
I will be hitting parts of my undercarriage and wheel wells with the spray in bedliner stuff as well.
To Underbody spray/bedliner spray
