Holley choke on a Demon
Location: At my Bar drinking and wrenching in Lafayette Colorado
Received 4,926 Likes
The black, round electric choke housing will interchange if you currently have a choke system on your BG carb. But you cannot install a Holley Choke Kit/System on a BG carb - the choke airhorn is different.
Why do you want to install a choke on your BG? If the carb is jetted and set up correctly, it will cold-start without a choke, and it will be slightly balky only for the first 2 minutes of operation - no choke needed.
Thanks Lars
