An old trick (bearing install)
Old Feb 22, 2005 | 02:05 PM
Gordonm's Avatar
Gordonm
Default An old trick (bearing install)
I am putting new gears in my Vette. I took a new bearing and honed out the pinion bearing so it is a slip fit while setting up the pinion depth. This keeps you from pressing the bearing on and off. Just enough hone to make it a slip but tight fit. Once I had it all set I put on a new bearing which is a press fit. I put the bearing in the oven at about 300 degrees for 20 minutes and the bearing drops right on the pinion shaft. When everything cools down it is solid on the shaft. Makes the install of a press fit bearing much easier. Just a quick tip.
Old Feb 22, 2005 | 02:34 PM
GTR1999's Avatar
GTR1999
Good tip Gordon. I used to use a bearing heater cone when rebuilding spindles out of Bridgeport Mills. The same thing, heat up the new bearings drop on. I also used a press many times. I must have rebuilt 100's of spindles that way.
Gary
Old Feb 22, 2005 | 02:41 PM
Edzred72's Avatar
Edzred72
So...I'm not only baking painted parts in the oven...I now have to bake spindles/pinion shafts too??? When will I be able to fit in the cake?
Eddie
Old Feb 22, 2005 | 04:57 PM
kevinator80's Avatar
kevinator80
Gary
Could the same results be achieved by putting the shafts in the freezer and leaving the bearing at room temp? I have put cylinder liners for diesels in the freezer before dropping them in the block. I ask because I am hoping to rebuild diff., replace bushings and bearings this summer.
Old Feb 22, 2005 | 05:13 PM
Gordonm's Avatar
Gordonm
Yes that would work also. Takes longer to freeze than to heat the bearings up.
Z-man's Avatar
Z-man
If you don't want to wait overnight for something in the freezer, I saw in one of the mags that a fire extinguisher was used to freeze parts during assembly. It has to be one of those CO2 ones (not the kind that spray powder! )
Old Feb 22, 2005 | 06:01 PM
Gordonm's Avatar
Gordonm
Heck man just go get some liquid nitrogen. That will freeze it instantly!
Old Feb 22, 2005 | 06:19 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
why not just put the slip fit bearing back on and forget about freezing your fingers off?
Old Feb 22, 2005 | 06:45 PM
mrvette's Avatar
mrvette
I think to put the bearing in the microwave and watch the fun as it heats up......
snicker.....
GENE
Old Feb 22, 2005 | 08:14 PM
Gordonm's Avatar
Gordonm
You don't want the pinion bearing to slip or rotate on the pinion shaft. It will score up the pinion shaft and eventually wear it down. This would give you some slop on that bearing which would not be good at all. The slip fit is just for trial setup to get the pinion depth set correctly. I like heating the bearing instead of freezing the shaft. I just wear a pair of Kevlar gloves when I pull it out of the oven.
Old Feb 22, 2005 | 08:18 PM
norvalwilhelm's Avatar
norvalwilhelm
With a press and a simple tool/plate pinion bearings are a 30 second deal to install or remove. I'm sure Gary you have one.
Old Feb 22, 2005 | 08:23 PM
Gordonm's Avatar
Gordonm
Not all of us have a shop that is full of tools. I do have a bearing plate and took it to one of my customers and used his press to get it off. I could not justify (or have room for) a press for this one job. I agree that is the best way to do it. Sometimes you just have to make do with what you have. Norval I wish I lived closer to you. I'd really like to see your shop!
Old Feb 22, 2005 | 08:29 PM
turtlevette
Originally Posted by Gordonm
You don't want the pinion bearing to slip or rotate on the pinion shaft. It will score up the pinion shaft and eventually wear it down. .
I don't know if i buy that. I might try slip fitting mine. I don't believe in press fitting anything.
Old Feb 22, 2005 | 08:34 PM
Gordonm's Avatar
Gordonm
You might get away with it for a while but every rear I have seen is a press fit on the pinion. GM made it a press fit for a reason. I'm no engineer by any means but I'm sure there is a good reason for it. Maybe Gary can enlighten us on this.
To An old trick (bearing install)
