I've been finding signs that my car lived it's previous life as a big block. Found Th-400 trans kick down switch on gas pedal. (bought car with ST-10) Found differential yolk straps (instead of SB u-bolts) on half shaft U-joints. 454 trim tag on shift console. How can I tell if my front coil springs are heavy duty, and used for a big block in 72? # of coils? coil diameter? They are installed so I can't measure uncompressed height. Radiator is not original. Vin tag not readable. Are there other signs I'm missing???
Thanks guys
Edie
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Thanks guys
Edie
You should have a 9/16" rear sway bar too. BB hood? What's the red line on your tach?
You should be able to tell which springs you have by the diameter of the wire the springs are wound from. In '73, the wire dia for an L48 w/A/c is 0.61 in. with a green tag marked with MA.
The big block springs are made from .65 in. dia. wire. I don't know what the code is for the big block springs.
Hello,
I read in a past issue of a Corvette magazine that some small block cars were modified to be big blocks. One of the items that they conversion missed was with either the Oil Temperature gauge, or the Water Temperature gauge. I cant remember which one it was, but there may be a difference in the temp. readings between big and small blocks. When I get home tonight I will see if I can find the article as a reference.
Any chance of getting to the build sheet on the top of the gas tank?
Yes, look for the rear sway bars (only the BB's had them I believe- did the F41 SB suspension have rear sway bars?) and also at the tach...this might be a clue. (Although I think that some of the 454's may have had some pretty low performance looking tachs.)
The little tag on the console shifter indicating you have a 454 is not necessarily determinative. Back in the late 1070's you could buy these things from GM for a dollar.
Sometimes the BB's had different overflow tanks than the SB. Also the radiator shroud can be a clue also in some years. For instance, a (1968?), a 1969, and 1970 BB radiator shroud can not be removed in a straight forward manner. The small block shrouds are easily removed. Basically stated, the BB radiator shrouds were molded so that they slightly overlapped the upper control arm attachment rods. This overlap made them very difficult to remove.
The suggestion to measure the wire size of the front coil springs is really good. Measure them with a caliper. If you don't have a caliper, and you're asking these kinds of questions, then I would respectively like to suggest it's time to buy a caliper!! (I'm always happy when I find another reason to buy another tool!!)
My 72 SB car has straps w/forged bolts instead of U bolts on the side yokes also. Also have a BB radiator and shroud, but don't have BB tach, rear sway bar. I think on some days during production, the assm ran short on some parts and it didn't hurt anything to go put more heavy duty parts on to keep the line moving. Why would elec kickdown switch be a clue for a BB? SB automatics have them also.
Original tank gone. Unfortunatly no sticker when I changed it.
I am familiar with the SB BB A/C no A/C overflow differences, but again....no overflow tank when I bought.
Rad & Shroud are not origin.
Looks like the only indicator I have left is to check the spring diameter.
Thanks for all your replies guys.
Eddie
I was under the impression that SB used the TH-350 auto which puts the kickdown on the carb linkage. TH-400 auto's were used for BB, which puts the kickdown on the gas pedal. Am I wrong???
Eddie
