Interior including seats redo big pics
Need another set of hands, I guess!
Hey! That's why I'm married! "Put your gloves on, Baby...we need to squeeze some foam!"
Any way...using the short hooks that come in those kits is tough...!
Thanks........good post and pics btw.
My covers are leather-like...$130.00, if I remember right...the foam was $110.00, I think. Both were from Willcox. The install kit was $23.95
Got one back cover attached to the foam this morning!
My wife and I worked out a system:
1. cut lasting on back of cover and insert wire
2. align cover and foam next to each other
3. mark foam where hole will go and mark lasting where hook will go so the two, hook and hole will be aligned and match up when the cover is on the foam
4. tie a 2 foot piece of twine to hook. Insert hook at marked spot on lasting. Do all hooks this way.
5. Put holes in foam at the marks I made earlier
6.With a spare wire push or pull twine through the appropriate hole in the foam. Do this for all hooks and twine and holes.
7. From the back of the foam pull all the twine so the foam sits flat against the cover. Make sure the lasting is in the groves in the foam. Lay it down on work surface so you are looking at the back of the foam
8. Wifey puts on glove, grabs one twine, puts foot on back of foam and pulls up on twine. This feeds the hook up through the foam.
8. I push backing wire through eye in hook.
Work your way around so all the hooks are hooked onto the backing wires so the foam and the cover are now one piece. It takes effort, but it is doable. It is much easier with a helper. You're now ready to put it on the frame. I'll post some pics later of the above, and tell you how it went getting it on the frame!
Wilcox seems to have the best prices, but I've heard good things about Al Knoch also. I just need to get off the fence and decide between leather and leatherlike. I would prefer leather, but the price and durabality of leatherlike makes it a tough choice.
Thank you again
