Still pulling to left
Old Feb 23, 2005 | 05:26 PM
MEGALADON's Avatar
MEGALADON
From: WAY DEEP INSIDE AMERICO,YES YOU LIVE HERE TO!! TX
Default Still pulling to left
I have brand new front and rear suspension, all new brake rebuild,
and they have been bleed correctly. I even micro polished my ss
sleeves in the calipers.
So why is my car sometimes still pulling to the left when I hit the brakes.
what other reasons are there, this is
Old Feb 23, 2005 | 05:28 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
tune in the radio to Rush Limbaugh.
are your brake pads new?
Old Feb 23, 2005 | 05:29 PM
foundvettelifeisgood's Avatar
tire pressure, alignment?
Old Feb 23, 2005 | 05:30 PM
MEGALADON's Avatar
MEGALADON
their not old, maybe about 300 mile on the SSBC performance pads.
Old Feb 23, 2005 | 05:31 PM
MEGALADON's Avatar
MEGALADON
All new, tires and pressure to
Old Feb 23, 2005 | 05:32 PM
Twin_Turbo's Avatar
Twin_Turbo
What about the brake lines? both the hard lines & the flexible ones (ruber or braid?) alignment???
Old Feb 23, 2005 | 05:39 PM
turtlevette
is it possible that any of the pads got brake fluid or oil soaked?
if not the other idea is......you might try a few hard stops to bed in the pads or give them a light sanding with 80 grit.
Old Feb 23, 2005 | 06:13 PM
timbo79's Avatar
timbo79
Seriously, based on everything stated, sounds like lines perhaps.....
Old Feb 23, 2005 | 06:41 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Sounds crazy, but might be worth swapping your LF and RF tires and see if the condition reverses. At worse, it will rule out tires.
Old Feb 23, 2005 | 06:49 PM
MEGALADON's Avatar
MEGALADON
Turtle, no soak of any type of fluid.
Big fish, I have directional tires
Twin_turbo, I have new braided lines.
the car sat for a long time (3/4) month.
I did flush my lines with alcohol, during the whole
rebuild, I did not want trash or old fluid in my calipers.
Maybe I do need to run it hard on the brakes
as for my hard lines, their clean, and none are bent.
Old Feb 23, 2005 | 06:55 PM
Big Fish's Avatar
Big Fish
[QUOTE=MEGLADON]
Big fish, I have directional tiresQUOTE]
Then try LF to LR, RF to RR...
Seriously, had this same problem with a Charger I once owned. After spending a fortune rebuilding the front end it wound up being bad tires.
Old Feb 23, 2005 | 07:14 PM
MEGALADON's Avatar
MEGALADON
[QUOTE=Big Fish]
I run 315/35 in the rear, and 275/40 in the front.
there is no way my 17/11 will work up front
Old Feb 23, 2005 | 07:35 PM
nostgry's Avatar
nostgry
Alright - You said you replaced the front suspension,. Would that include the inner and outer tie rods? Sleeves, drag link, ball joints? If so considering you rebuilt the calipers, I would say you have an alignment problem. Someone probably just counted the revolutions pieceing together your new suspension wrong. Quit guessing and get a computerized front end alignment. The front end specs DO go back to 68. Once you have the correct information on your alignment you can then take the appropriate measures to correct the problem whether it be tires, castor or camber to your front end. Get the diagnostic first.
Old Feb 23, 2005 | 07:46 PM
MEGALADON's Avatar
MEGALADON
I rebuilt the front end myself, everything that moves is new.
complete kit from VBP. I got my alignment this morining, it
did this before the alignment also a very good company
did the alingment for me. I do know how to rebuild a front end,
so I know there is nothing put on wrong or backwards
Old Feb 23, 2005 | 07:53 PM
turtlevette
i'm still fishing here,
did you take the brake pads out and put them in the same exact positions?
I still think its a simple matter of bedding in the brake pads.
you could take it back to the alignment shop and see what they say but i don't think its alignment related.
Old Feb 23, 2005 | 07:54 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
You're saying "sometimes" - it may be the road surface ...
What brand tires do you have ? I used to have 275-40-17 Sumitomo tires on my Camaro, they were pulling me all over the road when applying the brakes.... I bought some Goodyears and now it's perfect - I did not get the car aligned so I know it was the tires...
Old Feb 23, 2005 | 08:00 PM
MEGALADON's Avatar
MEGALADON
I've got sumitomo now, so you may have hit it on the spot
I checked the overview (comments) on tire rack and everyone there
bad mouthed sumitomo, only good fro trashing and cool burnouts
I still can't afford all my goodyear eagle gs d3 f-1's
To Still pulling to left
Old Feb 23, 2005 | 08:05 PM
GTR1999's Avatar
GTR1999
Mag- did you change the rubber hoses? They night be hanging up the caliper. They swell on the ID so they may look ok from the outside. Those tires could be the problem though.Do you have a "normal" set to try on the car for your shake down cruise?
Gary
Old Feb 23, 2005 | 08:11 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Gary
That's another potential cause.... if the hoses swell they act like a non-return valve... when you pressurize the sytem by pushing the brake pedal the pads are being pressed against the rotors - then when you release the pedal the pressure inside the caliper remains... there's nothing other than the brake rotor's runout pushing the pads back...
Old Feb 23, 2005 | 08:13 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
well.... if you have Sumitomo HTR 40 Z tires then I am sure that I hit the spot.... the HTR2 tires are not much better from what I've heard...
put some other wheels on the car and see what it does....
