Parking Brakes
Old Feb 25, 2005 | 01:53 PM
ram56's Avatar
ram56
Default Parking Brakes
I'm new to this forum and relatively new corvettes. I bought a 79 late last summer and enjoyed driving it the few months I had before winter set in here in MN. The previous owner (or one of the previous owner's) removed the parking brakes for obvious reason(s). Over the next few weeks I plan on doing some front suspension work and replacing the rear parking brakes. Can anyone advise or recommend stainless brakes over regular steel???
Thanks in advance.
Bob
Old Feb 25, 2005 | 02:28 PM
Boofers's Avatar
Boofers
Advice - have patience when you do it, it can be a good challenge.
Old Feb 25, 2005 | 02:35 PM
GTR1999's Avatar
GTR1999
Use SS hdwr kit and steel shoes, the SS shoes don't fit too good. If you want a parking brake that works- put a piece of 4x4 in the car,apply behind tire when parked. Works better then the stock system most times
Gary
Old Feb 25, 2005 | 02:47 PM
Gordonm's Avatar
Gordonm
I have the SS hardware on mine and they work pretty good. It will hold the car on a hill. It has been on the car for about 5 years now and they are still working.
Old Feb 25, 2005 | 02:54 PM
Edzred72's Avatar
Edzred72
I have installed stainless hardware and recommend steel shoes also. When installed/adjusted properly the P-brakes work just fine. This article gives a few helpfull tips that make it easier to do.
http://www.rowleycorvette.com/corvette_repair.html
Good Luck....and PATIENCE
Eddie
Old Feb 25, 2005 | 03:34 PM
kens 80's Avatar
kens 80
I agree with SS hardware and steel shoes, but I always put an extra coat of paint on the metal portion of the shoes. AND dont forget to put a good silicone grease or synthetic lube on the contact points where the shoes meet the backing plate.
Old Feb 25, 2005 | 03:46 PM
ram56's Avatar
ram56
Thanks for the advice, article and the tips. Much appreciated!
Old Feb 25, 2005 | 04:47 PM
mandm1200's Avatar
mandm1200
I did the same thing. When I was buying the kit, the vendor highly recommended that I use steel shoes with SS hardware. I'm not totally sure why but I took his word on it.
Old Feb 25, 2005 | 05:59 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
The SS Shoes are arched wrong. You have to sand down most of the shoe's surface just to make the rotor fit over it. You will not have any problems w/the steel shoes.
Old Feb 25, 2005 | 07:05 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Gary
I agree.... if you don't need the parking brake for your state inspection then a 4x4 is a good idea.....
It is called "emergency brake" because it's supposed to stop the car in case your normal brakes fail..... well, I guess most of you agree that even if in perfect condition this parking brake will not stop the car if the brakes fail at 60 mph......
Old Feb 25, 2005 | 08:15 PM
Z-man's Avatar
Z-man
The parking brake was never intended to be an emergency brake...
Old Feb 25, 2005 | 08:47 PM
69autoXr's Avatar
69autoXr
That's the reason for the dual master cylinder circuit.
Old Feb 25, 2005 | 08:53 PM
FeedVaal's Avatar
FeedVaal
I'm convinced the parking brake can work flawlessly. You only need to adjust it on a weekly basis.
Edited to include smilie...
Old Feb 25, 2005 | 09:00 PM
68/70Vette's Avatar
68/70Vette
I was told by someone ( I think Kenny at Toms Differentials) that the stainless steel parking brake shoes were shaped to fit used rotors. The message was that if you're using new brake rotors, don't use the stainless steel parking brake shoes. So what you need to do is buy the stainless steel parking brake mechanisms...that is buy all the bits and pieces for the parking brake in stainless steel, but buy the actual brake shoes in OEM steel. I did that and then painted my OEM steel brake shoe metal parts. The metal parts were cad plated, so I sprayed them with Krylon clear.
Old Feb 26, 2005 | 11:22 AM
ram56's Avatar
ram56
Thanks. I intend to replace the rotors because the one's I removed are rusted and erroded. I'm not a fan of turning older rotors as experience as shown they only warp from the heat. So, new rotors, stainless actuators, regular steel shoes it is.
Two other questions:
1. Do you guys actually put rivets back in the rotors?? Can't see the need for it myself.
2. Regarding control arm bushings, any opinions on urethane over the rubber?
Thanks again, your experience and advise is much appreciated!
Old Feb 26, 2005 | 01:00 PM
82Vette'ster's Avatar
82Vette'ster
I found a C2 (same mechanicals) article on Parking brakes that was taked about quite a bit. Might help.
Good luck
http://65corvette.nonethewiser.net/t...ke_springs.pdf
To Parking Brakes
