tiltin tires
Old Feb 26, 2005 | 04:16 PM
whiteflame's Avatar
whiteflame
Default tiltin tires
just picked up a 69 vette a weeks back. when my son was drining the car home i noticed the rear tires would tilt in at the top on uneven roads or turns. is this a strut rod problem ??? any info would be a plus. thnx dave
Old Feb 26, 2005 | 05:41 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Hard to say. Are the top of the wheels tilting inward at nornal stance? Are the lower strut rods straight as they should be or are they bent? Can you physically move the wheels back & forth with your hands? Things to look at are bushings, strut rods, trailing arms(rot/flex). Things to consider; wheel bearings, loose lug nuts (aluminum wheels can loosen), worn shocks.
Lots of questions, but hopefully it'll get you moving in the right direction
Old Feb 26, 2005 | 07:20 PM
markdtn's Avatar
markdtn
What he said. Sounds like the strut rod bushings are gone, but you need to look at everything back there as they are all tied together. May be a little bit bad everywhere, "tolerance stackup".
Old Feb 26, 2005 | 09:02 PM
whiteflame's Avatar
whiteflame
Default Tiltion Tires
thanks guys for the response. i'll crawl around and check everthing out. thnx for the response. dave
Old Feb 26, 2005 | 10:19 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
You could also have worn out axle yokes. Early C3's were notorious for wearing these out inside the differential wher the ends of the yokes contact the cross shaft. The more that's worn off, the more the wheels will tilt in. You should have no more then .050" end play in the yokes. Strut bushings and wrong adjustment may be other causes.
To tiltin tires
