Trailing Arms
Old Feb 26, 2005 | 07:44 PM
jd1a's Avatar
jd1a
Default Trailing Arms
I'm getting ready to replace the trailing arms on my 75. There's not much room to put the T arm bushing bolt in through the frame. How do you do it? I'm thinking a long pair of needle nose pliers and lots of luck. I haven't tried getting the bolt out yet. That may be fun in itself.
Old Feb 26, 2005 | 09:06 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
if it all rusted to one chunk of rust ... cut through the shims and the bolt , a reciprocating saw for $59 at Lowe's does the job.... the shims and bolts are getting replaced anyway...
Installing the bolt.... yes, that's fun.... I glued the bolt to needle nose pliers so it wouldn't slip off the pliers... worked great but took me a while to get the idea of glueing the bolt to the pliers...
Old Feb 26, 2005 | 09:18 PM
NC C3's Avatar
NC C3
Yep!! Needlenose is the key....also take a shop rag and cram it back in that space where the bolt goes....this will kinda keep the bolt from wiggling around too much while you are trying to get it lined up and fed thru the inner sleeve in the T/A....I just did my 78 today. The left side was easier than the right side because I am right handed and trying to teach my left hand precision needlenose motor skills just wasn't happenin'. Just have patience and you'll get it....Good luck
Old Feb 26, 2005 | 09:24 PM
john1977's Avatar
john1977
To install the new bolt put a piece of fishing line through the cotter pin hole in end of bolt and just pull it through.
Old Feb 26, 2005 | 10:17 PM
NC C3's Avatar
NC C3
awww c'mon.....thats cheating!!!
Old Feb 27, 2005 | 06:39 AM
john1977's Avatar
john1977
Hey that was just a little tip someone gave me a year ago when I was doing my t-arms. Does work good,maybe a couple of minutes to get the bolt back in.
Old Feb 27, 2005 | 01:27 PM
jd1a's Avatar
jd1a
Thanks guys. Looks like I'll break out the fishing line, have the needle nose pliers as back up.
Old Feb 27, 2005 | 02:15 PM
Z-man's Avatar
Z-man
I didn't have fishing line, but thin wire worked the same...
Old Feb 27, 2005 | 05:05 PM
swtato's Avatar
swtato
St. Jude Donor '05
I was at the Vette expo in Houston today and a guy at Van Steel told me to do the same thing. I thought it was a great idea and wanted to post it but alas you beat me to the punch!
Old Feb 27, 2005 | 09:07 PM
BEBOP138's Avatar
BEBOP138
Ditto on the fishing line---worked well when I did my 69.
To Trailing Arms
