I have a 72 454 with box stock engine. I think one of the heads have a crack. This engine must have a low rise intake and carb to clear the hood. I don't know if it is oval or rectangle ports. But I am searching for heads. I really would like to know the correct casting #'s and or leads to finding replacement or totally reconditioned heads. (not local parts house rebuild). I need to know they have been checked for cracks behind the valves and valve guide as well as the entire casting.
I have located many 72 454 heads for trucks etc.. but if it is newer than 72 the brackets for a/c etc won't mount up and I want to keep this engine as factory delivered.
Can anyone provide clues to this puzzle. Thanks.. 99 Nassau blue.
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Your head casting number should be 3999241 since there was only one 454 produced in 1972. You can confirm this by removing a valve cover and looking for the numbers stamped inside on the head. If you engine is indeed matching and a 1972, your head should be stamped with that number.
Thanks to both of you for the information on the heads. Just wondering would you know where to buy a replacement? I know new heads are available, but the the 72 454 LS5 engine what I understand is the acc. bracket holes are different from the newer engines. I really don't want to change all the bracket/pully set up.
I would also consider recondition of existing heads, but I believe I have a crack under the valve on at least 1 of the heads.
If you strike out on finding a correct head, consider a pair of '049 1973 454 heads. They flow better, but are 119cc so you have to check what your stock chamber volume is so that you don't inadvertantly drop the CR!
The car is losing water at a rate of about 2 qts/100 miles. There are no water external leakage. My thoughts were a crack behind the valve and going directly into the exhaust. The left bank smokes a lot at start up and normal driving.
There is no combustion gasses in the water and the engine runs 180 or so when there is water in the system.. Of course when it gets low after 100 or so miles of driving the temp goes up with the water loss.
The engine is chevy orange and absoultely no water outside and no water in the oil. This leads me to a head crack with water going into the exhaust.
But in either case if the heads are pulled and we find a crack the car will be down for extensive time. I don't have much faith in repairing cracked castings. I know it has been done and I have seen it,, but you really need a good skilled shop to make the repair and where the car is.. I don't think they have the knowledge or skill to make this repair. I would also prefer a replacement head to a repaired. Just a $.02 opinion. 99 Nassau Blue
Cracks in bigblock heads are unusual and rare. However, a quality machine shop can repair a crack professionally and you will never have a problem. Assuming, of course, that it isn't cracked like Aflac's! Sorry, bad joke at his expense. I feel for him.
I would suspect your water loss is coming from somewhere else. The smoke you are seeing at start up is more likely tired and worn valve stem seals rather than coolant. Those seals become very brittle after about 50,000 miles.
Steve I think you are right about some of the smoke being oil, but I also think we have the water leak in the head. Can't prove it though. When we pull the engine down we want to have all the parts ready to install on the rebuild. I have been looking into edelbrock for new aluminum replacements. It would be nice to have numbers matching factory 72 heads but new aluminum will be an option if we can't find
#'s matching. I am going to a NCCR swap meet at the end of the month and will look there. Thanks Jim
