Does this look like a good deal? Rotors
Old Feb 28, 2005 | 10:06 AM
OldSchool's Avatar
OldSchool
Default Does this look like a good deal? Rotors
How would a 'zinc coated' surface perform after a few stops? Anyboody ever bought from these guys?
Ebay Rotors
Old Feb 28, 2005 | 10:12 AM
mandm1200's Avatar
mandm1200
I don't think the zinc coating will affect them. The zinc will wear off with a couple of stops. The purpose is to keep the rotor from rusting in the area's the pads not not toutch.
Old Feb 28, 2005 | 11:16 AM
NHvette's Avatar
NHvette
$135 for the pair to start ... no hubs.
I think you can do much better.
You can get Raybestos Brute stop rotors (drilled 'n' slotted) for
just over $50 at rockauto. Raybestos PG Plus rotors are just over $20 each.
Old Feb 28, 2005 | 03:17 PM
73jst4fun's Avatar
73jst4fun
Anyone have any experience with the Raybestos brute stop rotors, they are priced right, and do they make them for the rear also to match the front.....
Old Feb 28, 2005 | 04:54 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
I think the Raybestos prices are great. Mine are Powerstop and they costed about 30% more for drilled only. At $50 each for drilled and slotted it is very reasonable. Raybestos specialize in brakes so I would say they are a pretty safe bet.
Old Feb 28, 2005 | 04:57 PM
stingry's Avatar
stingry
Ebay Rotors
I had the cadmium coating on mine. It rubs off and clogs up the brake pads in the first 50 miles. Makes you stop like crap as you are glazing the pads with the zinc/cadmium. You need to use old pads till the zinc/cadmium wears off THEN put your new pads on. I went through two sets of pads to work that little gem out. My rotors are almost 18 months old and look great thanks to the coating.
Good Luck,
Pete
Old Feb 28, 2005 | 06:18 PM
OldSchool's Avatar
OldSchool
Good Luck,
Pete
That's exactly what I was thinking.. Thanks
Old Feb 28, 2005 | 07:12 PM
cruzzin-style's Avatar
cruzzin-style
Hi: www.rotorpros.com. Check thses guys out. I got some from this guy. The rotors look great. The zinc coating has not come off yet. even where the pad touches still looks good. Their prices are good. None of the ront rotors come with the hubs. Not for those prices. You have to drill out the rivets on the hubs of your original rotor & hub assembly. I drilled out 4 holes like on the original rotors & then used grade 8 nuts, bolts, & lock washers.
Old Feb 28, 2005 | 10:46 PM
pef427's Avatar
pef427
If they don't come w/ zinc coated hubs and the coating rubs off of the rotor/brake pad contact patch...someone please tell me what is the advantage to putting your old refurbished hub on and then have it all look like crap soon again?????? Seems to me the zinc coated hub would be the iceing on the cake to go with the drilled/slotted rotor!
Old Feb 28, 2005 | 10:51 PM
cruzzin-style
Hey, that's a good question. I painted mine with a Silver Epoxy paint. They look pretty good.
I paid 200 bucks for all 4 corners for my C3 from www.rotorpros.com
Old Feb 28, 2005 | 10:52 PM
cruzzin-style
Oh yeah......that was with shipping included..........
Old Feb 28, 2005 | 11:34 PM
kettererhouse's Avatar
kettererhouse
Ebay Rotors
Item number: 7958060477 I agree with NHvette you can do better!
i was looking at the ebay listing above, thought about raybestos @ 200.00 but everything i have heard is CAST STEEL is cast steel, as long as the rotors true should be no problems! But if ya want to spring a extra $50.00 ?? Thanks for the TIP stingry about using old pads to clear the zink off! makes sense, Im redoing all the brakes on all 4 corners new lines new master new ss calipers new ebrakes & ss hard ware Might as well get the slots and cross drills, get all the stop power i can for the 427
To Does this look like a good deal? Rotors
