Tech: Question about intake gaskets...
Old Mar 3, 2005 | 02:33 PM
406shark's Avatar
406shark
Default Tech: Question about intake gaskets...
Hello,
I have a question about FelPro 1205 intake gasket set. Actually two questions.
FelPro has the blue ring around all the ports...do I still need to use RTV around the water ports?
They don't have a steel/aluminum plate in the set that will block off the heat crossover opening. Can these be purchased? If not, what thickness and material would be best to use to make a set?
Thanks,
Jeff
Old Mar 3, 2005 | 02:51 PM
Fevre's Avatar
Fevre
What size ports do you have? The 1204 is blocked but only 1.99 x 1.23, the 1266 has 2.21 x 1.31 ports and is also blocked. I have used small peices of sheet metal in the past but decided to get some that had the blocked crossover this time.
Old Mar 3, 2005 | 02:59 PM
406shark's Avatar
406shark
I have the Sportsman ll cylinder heads...they recommend the 1205 gasket set. The 1205's fit the Sportsman ll's perfect as far as the openings go. On my previous engines I always got a set of the blockoff plates with the intake set...
Anyone have an extra set of blockoffs laying around?
Thanks,
Jeff
Old Mar 3, 2005 | 03:00 PM
The Dude's Avatar
The Dude
I would--just a skim coating though. Don't go crazy with it. A little on the head, a little on the gasket. Lay down the gasket and put another skim on the top of the gasket and around the water ports of the intake. Let it get a little tacky then install the manifold.
There are Fel-Pro intake gaskets that block the crossover without those little metal plates--The holes just aren't punched. I use them on my engine but I can't remember the part number right now. It MIGHT be 1206 but don't quote me on it.
Old Mar 3, 2005 | 03:18 PM
Fevre's Avatar
Fevre
Thanks,
Jeff
It would be odd if Felpro did not make a version of the 1205 with blocked crossover, the gaskets I refered to do not have a hole at all so no alu peices to deal with.
Old Mar 3, 2005 | 03:26 PM
406shark's Avatar
406shark
Now I feel really stupid... :o I went and checked my intake gaskets and found that I was looking at the wrong gasket set. I just threw the stock intake set up in a cabinet so I don't do something stupid and try and install them on the wrong engine.
The 1205's DO NOT have an open crossover.
Thanks for the help, sorry for wasting your time.
Jeff
To Tech: Question about intake gaskets...
