I would like to know whats the best way to remove steel sleeves from the control arms. I will be replacing them with VBP Poly bushings with new sleeves.
Before I realized that the sleeves were to be replaced too I removed the old rubber bushings.
Yep, air hammer works the best. Or you could take a chisel and hammer and fold half of the sleeve into the inner portion where the bushing was. Once it is loose in the a-arm it can be tapped out.
Why not? You get new ones. You might as well replace the sleeves. I wouldn't put rusted sleeves on new bushings. If there is a bur in the sleeve you can start to rip the bushing before you even install it.
Why not? because I can't get them out, Can't budge it even with a air chisel, So far I have not damaged them and they are not rusty. so why can't I just use the origanals and save the hassel?
(these are the outside sleeves that install in the control arms )
John
it is best to replace.. but if you cant then check for burrs.. and lube them good.. i use an air chisel as well... never had a problem getting them out..
