spindle twisted
Old Mar 4, 2005 | 08:25 PM
mikie77's Avatar
mikie77
5th Gear
Default spindle twisted
I have never gotten to this befor . My 1st vette. Are there special tools need to replace and what might the process be. I want to go a little stronger than factory so would it be better to buy complete assemblies for both sides or just rebuild stronger with individule peices?
Old Mar 4, 2005 | 09:05 PM
68/70Vette's Avatar
68/70Vette
I don't know if I understand. People use the word "spindle" for several things.
To me a spindle is the solid cast iron shaft that fits between the upper and lower control arms and has a orthogonal shaft, the "spindle," to which the front wheels are attached. After you stack the spindle with inner bearings you then add the "Hub" and then the outer bearings. Once you've got the "hub" installed you can mount the front wheel. Is this what you're talking about?
I think spindle is mostly associated with the front wheels. Are you perhaps referring to the rear wheels?
If you're a beginner, you have a good chance of replacing the front bearings and bearing races by yourself. For the rear wheel bearings, it's really the best idea to have an expert shop do that. My opinion.
Old Mar 4, 2005 | 09:31 PM
GTR1999's Avatar
GTR1999
Rear spindle twisted under load. Lucky you caught it before it sheared off- you did catch it before right? What are you using the car for? If you're just going to drive it and occasionally dump the clutch or bang 2nd gear the stock spindles or Tom's are good. If you going to go drag racing then you're going to need more then spindles or you're going to breaking other parts too. How are the U-joints and side yokes?
PM me if you want to go over repairing them.
Gary
Old Mar 4, 2005 | 11:05 PM
wattac2's Avatar
wattac2
If you're a "I've got the time and want to learn" type then read up on the spindle and give the replacement a try. Many have successfully. If you're not comfortable with very, very close tolerances and heavy tools, pay someone for the rebuilt T arm and enjoy your Vette.
Old Mar 4, 2005 | 11:11 PM
redvetracr's Avatar
redvetracr
IF you or anyone else is interested I have an extra brand new in the box NOS GM rear spindle for sale...e-mail direct if interested.
...redvetracr@msn.com
Old Mar 4, 2005 | 11:23 PM
68/70Vette's Avatar
68/70Vette
From what I can tell, it appears to me that you have a rear half-axle problem. I wouldn't call a rear half axle a "spindle" since spindle is a pretty generic word. The Corvette half axles are really just like a full size axles, except instead of being 3 1/2 feet long, they are perhaps 10 inches long. Just because they are a little bit shorter, I don't think you should call them "spindles." They are AXLES. I prefer to use the word "half-axle, because they area little bit short."
Actually, I think spindles are things that are on knitting machines.
Old Mar 4, 2005 | 11:28 PM
wattac2's Avatar
wattac2
You'll have to clarify, are you referencing the "tubes" that tie the differential to the "spindles", or are you talking about the true spindles that are part of the T arm assemblies? The spindles do exist and are what the wheel is attached to, and are held in place by bearings and the T arm.
Old Mar 4, 2005 | 11:53 PM
68/70Vette's Avatar
68/70Vette
I've looked at the above message. I see the words "tubes that tie the differential to the spindles" ...or true spindles that are a part of the T arm assemblies." There's the next really informative statement "The spindles do exist and are what the wheel is attached to..."
What are "tubes" or "true spindles." What I see when I try to read the above is I just see a lot of gobbled-gook words.
Look in a parts manual and get the correct words for parts that you'd like to talk about and then please describe your problem in very clear words.
Old Mar 5, 2005 | 09:21 AM
mikie77's Avatar
mikie77
5th Gear
i am talking about the actual part that the lug nuts are on and the half shaft bolts up to on the other side and it is shear off.
Old Mar 5, 2005 | 11:49 AM
GTR1999's Avatar
GTR1999
You are correct, that is the spindle. It connects to the 1/2 shaft which connects to the rear end side yoke. U-joints in between. You're going to have to rebuild the rear wheel bearing assembly. You will need a good spindle and maybe a spindle flange if those spines are also damaged. I couls write up the whole procedure but it's easier to explain on the phone. Like I said PM me and we'll talk.
Gary
To spindle twisted
By Michael S. Palmer | 2026-06-03 11:00:24
