Steering ratio
Old Mar 6, 2005 | 07:26 AM
2002SSSLP's Avatar
2002SSSLP
Default Steering ratio
If I remove the power steering assist cylinder from my car, is it basically the same as a factory manual steer? Same ratio that is. This car will become a street strip car with emphasis on strip.
Old Mar 6, 2005 | 07:34 AM
mrvette's Avatar
mrvette
Except the drag link has a special valve in the Pittman arm end, and so intruduces a bit of slop in the steering...the manual drag link has no slop....with typicak front drag tires, meaning small, the valve is no problem, but on the street, I feel it introduces wander in the steering, especially with modern wide tires....
GENE
Old Mar 6, 2005 | 11:37 AM
GTR1999's Avatar
GTR1999
Tommy to switch to manual steering you need to swap to a manual pitman arm, manual center link and can remove the plug in the knuckle and use either hole to alter steering ratio. The boxes are the same.
Gary
Old Mar 6, 2005 | 11:40 AM
2002SSSLP's Avatar
2002SSSLP
Thanks for the info guys !
To Steering ratio
