79 Diff fluid
Old Mar 7, 2005 | 02:28 PM
79Brian's Avatar
79Brian
Default 79 Diff fluid
Ok I would like to replace the diff fluid in my 1979. How much of a pain is this? So far I have the half shafts out and the spare tire carrier. Look to me like the spring has come come out. I would also like to drop the fuel tank while I have the space open. Is this also a pain?
Old Mar 7, 2005 | 02:37 PM
Neo Fender's Avatar
Neo Fender
I simply removed the spare tire carrier and siphoned as much as the old, nasty stuff as I could with a hand pump through the side fill plug. Capacity is something crazy like “1/2 inch below overflowing”. I just filled mine to overflowing and it’s been fine for three years. Don’t forget the posi additive.
Old Mar 7, 2005 | 03:03 PM
79Brian's Avatar
79Brian
The start of this project was to replace the gasket on the diff. Its actually leaking a little bit. As for dropping the tank I would like to do it just to clean it out and put a new sending unit in it. The sending unit is working but I have most of the stuff out of the rear of the car right now so why not do it while is available I guess is what I am thinking.
Old Mar 8, 2005 | 02:25 PM
79Brian's Avatar
79Brian
It actually wasn't that bad. I just removed the two bolts from the crossmember and all the diff cover bolts and it all came off just fine. OHHH and I put a jack stand under the diff so it wouldn't lay on my exhaust. Cover is off and the gears look great. Not bad for 25 years old. I was very low on fluid though. Now to get is all back on there
To 79 Diff fluid
