Wot!!!!!
Old Mar 7, 2005 | 10:08 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Wot!!!!!
Installed my new Lokar gas pedal assembly tonight... I'm finally getting WOT and not only 75% throttle like I used to with the POS '68 pedal assembly...
Old Mar 7, 2005 | 10:21 PM
74FLCONV's Avatar
74FLCONV
Let's hear it!
D. Ocean
Miami, FLA
Old Mar 7, 2005 | 10:34 PM
lostpatrolman's Avatar
lostpatrolman
So did you actually test it??
Is the rear still giving you problems?
Old Mar 7, 2005 | 10:53 PM
GrandSportC3
The rear hasn't been acting up since I installed the new engine.. I still don't want to risk racing or driving hard with the current rear end...
I'll have to wait until I'll get the 12-bolt setup... Hopefully, that'll be soon..
I had my roommate check on the carb if it was WOT when I floored the gas pedal...
Old Mar 7, 2005 | 10:54 PM
GrandSportC3
Originally Posted by 74FLCONV
Let's hear it!
D. Ocean
Miami, FLA
Not yet....
Old Mar 7, 2005 | 10:55 PM
oregonsharkman's Avatar
oregonsharkman
Post a vid or sound clip....I still am waiting to hear your new motor bud!!!....
Old Mar 7, 2005 | 11:02 PM
GrandSportC3
Just made some space on my webpage...
here's the best video so far...
http://www.corvetteforum.net/c3/grandsportc3/drive2.wmv
Old Mar 7, 2005 | 11:41 PM
Budman68's Avatar
Budman68
Cruise-In VII Veteran
St. Jude Donor '07
I'm going to be in Tampa on Thursday. I'm ready for my ride.
Old Mar 8, 2005 | 12:19 AM
lostpatrolman
budman, is your car down here in florida?
Old Mar 8, 2005 | 12:41 AM
Joe Buck's Avatar
Joe Buck
Car sounds good after the stop sign, but before that it sounded like a lawnmower engine! Just wondering, but what kind of exaust work have you done to it?...
Old Mar 8, 2005 | 12:44 AM
oregonsharkman
Nice vid Olivier.............motor sounds bad...........what is your stall converter?? 4000rpm your neighbors must luv you....vroom vroom
Old Mar 8, 2005 | 07:51 AM
Budman68's Avatar
Budman68
St. Jude Donor '07
No, I wish.
Old Mar 8, 2005 | 10:13 AM
lostpatrolman
Thats sad. I would have loved to see it...
Old Mar 8, 2005 | 10:31 AM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Awesome, now you'll be going somewhere. Little problems like that can be really annoying.
Old Mar 8, 2005 | 10:55 AM
fontking1a's Avatar
fontking1a
The stock throttle assembly works OK. I'll bet all you needed to do was to tighten the nut down on the floor board behind the gas pedal. My 3X2 was doing the same thing and once I tightened the nut, it worked as it should. The nut took about 1.5 or 2 turns and that made all the difference.
Old Mar 8, 2005 | 12:45 PM
81' Corvette Guy's Avatar
81' Corvette Guy
Bet he was scared $hitless..holding on for dear life under your tilt front end with a flashlight looking down the throat of the carb to see if the secondaries were wide open... while you were flying down the strip..
Old Mar 8, 2005 | 01:24 PM
79VetteMike's Avatar
79VetteMike
do you have the part number ?
To Wot!!!!!
Old Mar 8, 2005 | 08:45 PM
GrandSportC3
Give me a call when you are in town....
I'll PM you my phone number...
I don't know what time I'll be able to leave work on Tursday.. Have been working overtime lately..
Old Mar 8, 2005 | 08:50 PM
GrandSportC3
4500 RPM stall speed...
Old Mar 8, 2005 | 08:51 PM
GrandSportC3
http://store.summitracing.com/defaul...=KeywordSearch
