The Yokes on me...
Old Mar 8, 2005 | 05:19 PM
FeedVaal's Avatar
FeedVaal
Default The Yokes on me...
Found this when I pulled the differential this weekend...
Also it looks like the bolts I got with my new spring were a tad long...
I have no idea why the sideyoke failed as it was no more than 2 years old and I mostly drive like the 50 year old I am, no hard launches or screeching turns. I can only surmise it was a metalurgical failure.
I'm replacing the yokes w/ HD capped units and replacing the differential as there was other general wear. My question is can the cover be welded?
I just bought a used stick welder to attach the crossmember I cut out but have no experience with cast iron.
Old Mar 8, 2005 | 05:33 PM
GTR1999's Avatar
GTR1999
Not good. The yoke looks like original one that just failed? When rebuilt they only replace the tip, I don't think the yokes are machined that deep?
Use a new HD cover. Check with Muskegon, we ran a group purchase here a few years ago for $50 each I think.
Gary
Old Mar 8, 2005 | 08:53 PM
Gordonm's Avatar
Gordonm
Get a new cover. They are not that expensive. Cast iron can be tricky to weld if you don't have the knowledge or right equipment.
Old Mar 8, 2005 | 09:40 PM
Solid LT1's Avatar
Solid LT1
Save the cover and teflon tape your spring bolt, now you have a "handy" differential drain plug!
Old Mar 9, 2005 | 12:17 AM
FeedVaal's Avatar
FeedVaal
That thought didn't occur to me. When life hands you lemons...
Old Mar 9, 2005 | 01:06 AM
StudDawg380's Avatar
StudDawg380
Throw them back, screaming, "I ASKED for LIMES!"
Old Mar 9, 2005 | 06:17 AM
Gordonm's Avatar
Gordonm
That will not allow all the fluid to drain. The hole is up to high. You need a hole at the bottom to drain all the fluid.
To The Yokes on me...
