Blocking off EGR Valve
Old Mar 8, 2005 | 10:40 PM
colorado1967's Avatar
colorado1967
Default Blocking off EGR Valve
Has anyone had problems with using a block-off plate for the EGR Valve? I heard or read once doing so can create carbon build up in the manifold.
Any knowledge shared is appreciated.
Old Mar 9, 2005 | 07:20 AM
vetteonr's Avatar
vetteonr
I blocked mine off about 8 years ago. No ill effects so far.
Old Mar 9, 2005 | 08:37 AM
colorado1967
Thank you, Good to know.
Old Mar 9, 2005 | 10:01 AM
page62's Avatar
page62
It can indeed create carbon buildup in the exhaust crossover. My car had the blocking plate in place when I bought it. When I did the head swap, there was carbon in the passages below the plate.
However, I don't consider it to be a serious issue...
Old Mar 9, 2005 | 10:33 AM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
Exhaust Gas Recirculation has no ill effects though. It is a harmless smog device that can reduce cylinder temps, and thereby actually reduce ping.
the only anomoly is carbon and that is easily cleaned. Valves last at least a 100K miles, and you know when they go bad (sticking open) by the bad idle. Of course, the system that sends vacuum to open the EGR could go bad too, causing it to get vacuum at idle - but that's a rare event.
Why do you want to get rid of the valve anyway?
Old Mar 9, 2005 | 05:02 PM
SLVRSHRK's Avatar
SLVRSHRK
Would the bad idle be only at startup, or all of the time? My 78 has a terrible time idling when it first starts and I'm just wondering....
Old Mar 9, 2005 | 08:59 PM
Super Stock's Avatar
Super Stock
Blocked mine 25yrs. ago . No problems. No carbon.
Old Mar 9, 2005 | 09:28 PM
page62's Avatar
page62
No. You got other problems. See if you can find a copy of Lars choke adjustment procedure.
Old Mar 9, 2005 | 09:33 PM
StickShiftCorvette's Avatar
StickShiftCorvette
EGR hurts engine performance. By adding exhuast mixture to the combustion chamber through the intake valves, there is a lower mass of power producing fuel/air mixture that can be burnt in the limited (by displacement) chamber- that produces less power.
Old Mar 10, 2005 | 06:10 PM
joe73vette's Avatar
joe73vette
IN PART
HOWEVER, that is only at part throttle, so it doesn't matter,and actually lets you run more advance. At full throttle the vacuum goes away and the valve closes. EGR is a lot like vacuum advance, it's only there when you can use it, and goes away when it hurts performance.
There is no good reason to disable the EGR.
Joe
To Blocking off EGR Valve
