Stupid question but how Do differential gears work?
Is it the amount of rotations of the driveshaft for every turn in the tire? Or is it the amount of teeth in the larger gear (The one attached to the axel I believe) To the amount of teeth on the smaller gear (The one on the driveshaft)?
I just want to know what size gears are better for what as I have no idea what size gears are in my 81 and would like to change em. (they are stock, anyone know what stock gears they had?)
According to the corvette restoration guide the 81 came with 2.87:1 (positraction with automatic, code OJ) or 2.72:1 (positraction with four speed, code OK)
When you hear a gear ratio stated it means the number of times the drive shaft turns per 1 rotation of the rear wheel, ie if you have a 3.70 rear end the driveshaft turns 3.7 times per tire rotation. You can determine your gear ration by jacking the rear end of your vette off the ground and rotating the tire 1 rotation and counting the revolutions of the driveshaft, helps to mark the shaft. The higher the gear ration the more torq that is applied to the rear end thus making easier for the eng to turn the tires, but is also reduces the distance the car will move so you trade the ability to accelerate faster for less top speed and lower gas mileage. You will need to change the speedo gear in the trans to match your new gear ration if you replace them.
The ring gear is the big one... attached to the wheels. When it turns one revolution, the wheel turns one.
The pinion gear is the small one... it drives the big one from the engine/driveshaft.
The ratio is the number of teeth of the ring gear (larger number) divided by the number of teeth on the pinion gear (smaller number).... so you'll always have a number greater than 1.
"4.11" would actually be 4.11:1 or 4.11 revolutions of the driveshaft (not engine) to one revolution of the halfshaft. The higher the ratio, the faster the car accelerates, but the slower mph it will max out at in any given gear. 4.11 and higher rear end cars are generally not fun on the highway because of the high rpm (3000+ rpm) of the engine at those speeds. Lower ratios, like my 2.73, are meant for better economy on the highway or higher top speeds.
if you want to be picky, the ring gear is attached to the posi case, not the wheels. The wheels, connected to the stub axles via the halfshaft are connected to the vertical spider gears, these are interconnected w/ horiz. spider gears on a center shaft and this setup is connected to the case by a clutch pack.....the stubs slide into the splines of the vertical spider gears. The posi case, spider gears & clutch pack make up the positraction part.
yeh... but I didn't want anyone to see me pickin'.
Someone wrote it down not long ago,.... I think it was in the posi tuning topic, that was the best writeup I've seen on it...you're right, it is damn hard to put into words, maybe with a pic or an animation it could be done.
Engine power output doesn't change; just the way it's used.
It's a matter of leverage. Ever need to grab a bigger (longer) wrench to remove a stubborn fastener? Higher gears are the same as a longer wrench. They allow the engine to apply more force to the tires, but they have to turn slower as a result.
The above quite obviously true, but as a young kid with only a single speed Schwin bike, I had NO CLUE as the the affect of gears upon much of anyting.......today's kids got THAT comparo made into the seat of their pants....
