A C Condenser Question
Old Mar 10, 2005 | 08:32 AM
RDOldcars's Avatar
RDOldcars
Default A C Condenser Question
The 1970 Vette (big block) I bought has factory air but the condenser was missing. I am replacing the condenser and dryer, my question is this, do I replace it with a condenser made with aluminum tubes and fins or one made with copper tubes and aluminum fins? Is one better then the other? I believe G M original condensers were all aluminum. Does one work better then the other? I can buy a GM one for $200.00(NOS) (all aluminum) or a repro copper/aluminum for about $130.00. I live in Florida so I want the most efficient one I can get. Please advise. Any help would be greatly appreciated.
Bob in Boca
Old Mar 10, 2005 | 09:04 AM
Steve's74's Avatar
Steve's74
Aluminum will typically transfer heat better.....
Steve
Old Mar 10, 2005 | 10:02 AM
jimcork1's Avatar
jimcork1
Default Aluminum cools faster
Copper will last longer. So if long life is not your issue go with aluminum. The aluminum has a faster transfer of heat so faster cool down. Both will cool the almost the same so you won't notice a difference after the car has been rolling and cooled down. The excess air from movement will make both cool almost equal.. But if you like a very fast cool down on a really hot car,, the aluminum will be faster to cool and lighter.
Your choice, but MAKE sure they fit properly. 99 Nassau blue
To A C Condenser Question
