I have read several posts here about you guys moving the bracket to the top of the t/a. I'd like to see a couple of pictures to get a general idea of placement.
The previous owner put 8" (AZ code) rims on the '68, and it looks like the tire flexed a little bit too much and took the left braket right of the t/a. The right one only has about 1.5 mm clearance. I ordered the new brackets, but dont want to wory about taking a turn too hard and losing the parking brake again.
Pics please!!
As always, all help is greatly appreciated!!!!
~Rich
Is it best to just hook the cable to it and find a good spot for it where it wont bind or interfere with anything??? Or is there a certain "correct" spot where it should be placed?
~Rich
That should work fine, attach the cable to it and see where the bracket "wants" to be... there is enough adjustment in the cable (adjustment screw/nut) so I don't think the bracket has to be within a few thousands of it's original location..
Hopefully somebody who has done this sees this and posts a photo for you...
Thats what I'm hoping for. Thanks for your input though. I may just try to eyeball it and see what happens. If its wrong, I get to play with the grinder again. Thats always fun!!
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I gave thought to doing this and read about it here on the forum but my new t-arms were powder coated when they came in and I just didn't have the heart to ruin the coating to move the brackets. Maybe later on I will attempt this one. If you do it, make sure to post some pics. If the search worked I am sure there have been pics of this done on here before.
