body mounts
Old Mar 10, 2005 | 04:41 PM
JDRez42's Avatar
JDRez42
Default body mounts
My car is up on the homemade ramps right now cause i just got done with my clutch but was going to do my body mounts and was wondering if you guys ussually just have the car on the ground. mThe problem is thatr if its up on the ramp i can't really can't jack it up high enough to take my tire off.
Old Mar 10, 2005 | 05:31 PM
Codeman's Avatar
Codeman
7th Gear
I just finished my body mounts on my 77, I had the frame up on 4 jack stands and I jacked the body off from there. Careful its a ton of weight to be moving around.
Old Mar 10, 2005 | 06:55 PM
john1977's Avatar
john1977
I leveled my frame on jack stands before raising the body,be sure to soak the bolts with pb blaster for a couple of days before attempting to remove and take your time. If they wont break loose,dont force them turn a little then turn them back and keep soaking with pb blaster. You really dont want to snap #2 or #3 mount or you will have to lift the body off to replace the cage & nut. I averaged about 2 hours per bolt to get out without breaking them on #2 & #3 . As far as #1&4 I didnt worry about breaking as you can get them replaced without removing the body.
To body mounts
